Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Honda, Yamaha, Kawasaki, Isuszu Generators
Honda, Yamaha, Kawasaki, Isuszu Generators Restoring, maintaining and operating Honda, Yamaha, Kawasaki, Isuszu, and clones.
Honda EU7000is vs Eu6500is
this thread has 21 replies and has been viewed 1784 times
Old 04-08-2018, 04:38:48 AM
GeneratorNewb GeneratorNewb is offline
Default Re: Honda EU7000is vs Eu6500is
This winter was particularly cold and got down to -7 one night. Normally we have a few nights around -2 or -3.
If I changed the oil once per year with 5w30, will it still be fine to run that oil in the summer?
Also, I see Honda has a non synthetic, synthetic blend, and full synthetic. I was thinking to use the SAE 5w30 by Honda Power Equipment because it appears to be made for Honda 4 cycle engines. However, I don't think it's synthetic. Which one do you guys recommend with the eu7000is? Thanks so much!
Old 04-08-2018, 07:11:40 AM
csareb csareb is offline
you WANT to use conventional oil for the first 2-3 oil changes anyway. change oil after first 5 hours running, then again after an additional 12 hours running, then run it for 24 hours and change oil again. at this point you can sqitch to full synthetic, and should treat the oil with molybdenum (MOS2) additive at this time. change oil every 100 hours after that. Honda power equipment oil is good oil, the molybdenum treatment is just an extra layer of protection for internal parts to help keep everything working as it should. Mix a bottle in 2.5 gallons of oil, and mix thoroughly, then add the appropriate ammount to fill the crankcase after draining the old oil. mix it exactly like that. one 300ml bottle of MOS2 treatment to 2.5 gallons of oil conventional or synthetic dont matter. dont add more than one bottle of MOS2, and don't mix the 300ml bottle in less than 2.5 gallons of oil. too much MOS2 can actually cause problems rather than preventing them.
5w-30 is a little light for summer use, unless you live in northern Canada, Alaska, or similar climates. 5w-40 10w-30, or 10w-40 is better suited to average summer temeratures, and 10w-50 or 15w-40 in extremely hot weather, and 5w-40 or 5w-50 for desert (cold nights hot days) use. if youre unsure what climate zone you fall into, go with 10w-30 as it fits the middleground of temperature ranges and will work reasonably well to a point in warmer or cooler climates (just not so well below 0 dergees(f))
Old 04-08-2018, 07:31:44 AM
I'm in climate zone 5. I'm assuming you think 10w30 is fine for this climate zone then.
Do you happen to know if the Honda Power Equipment oil is synthetic or not? Is there any downside to running this oil exclusively? If I do, will the oil change intervals be shorter? Thanks!
Old 04-08-2018, 11:37:00 AM
yes 10w-30 is fine for your climate zone.
I believe Honda sells both synthetic and conventional oil. Synthetic oil should be clearly marked.
No there is no downside to running that oil exclusively. oil change intervals will be the same.
Old 04-08-2018, 12:29:29 PM
Vanman Vanman is offline
Motor oils have very carefully developed additive packages. I would personally be leery about adding foreign substances to them. And bear in mind that your fuel injected engine very likely has an oxygen sensor for efficient, closed loop operation. Like catalytic converters, these are sensitive to what is in the oil and the fuel.
As for the weight of oil, I would follow the manual. Engines are designed with particular clearances for certain oil viscosities.
As to the brand of oil, I would pick one from the list seen here:
https://www.google.com/amp/s/540ratb...t-ranking/amp/
Old 04-08-2018, 11:36:21 PM
adding MOS2 to the oil isnt going to cause problems as long as you follow the directions on the MOS@ additive and mix it in exactly the ammount of oil specified (usually 300ml to 2.5 gallons of oil). MOS2 provides an added anti-friction barrier, and should actually reduce emissions slightly if anything. of course the additive may not be necessary depending on the formulation of the oil you choose. some oil already has a lot of MOS2 in it already. check the formulation by researching your chosen oil online. if it has between 1000 and 2000 ppm MOS2 you dont need the additive.
Old 07-01-2018, 03:39:37 PM
LightsNE LightsNE is offline
Originally Posted by AlexV View Post
My understanding is the breaker kept tripping under normal load. The problem with paralleling 240v is the generator's don't pickup the load equally and you get a buildup of neutral cross current. Its no good for the inverters.
Our paralleling kit has been on the market for two years powering every thing from food trucks, motion picture lights, to large truck mounted LED advertising screens. We offer different configurations for different applications (use this link for details.)
Guy Holt, ScreenLight & Grip, Lighting Rental & Sales in Boston
Old 07-04-2018, 03:58:39 PM
Troy.honda Troy.honda is offline
Hi guys. New here. I have a Honda 7000is that had 450 hours on it and caught fire. Fire was a freak accident and not manufacture defect. Melted the front pretty good, but the motor is in tact. I took everything apart and the motor didnít have any damage. I also have a eu6500is with 5000 hours on it. It finally laid down this spring. My question is will the motor from the 7000 be able to be swapped with the motor from the 6500? Thanks!
Old 09-03-2018, 08:19:46 AM
bugle bugle is offline
How does your generator perform in cold weather? I have purchased 2 new Honda inverter generators, a 2000 and a 3000 and I am extremely disappointed with performance below 20 degrees f. The dealer told me nothing was wrong with them and that Honda didn't cover fuel system problems under warranty but they would be glad to replace the carburetor for xxx dollars.
I'm off grid solar and with winter coming I need to buy a generator soon. I can't find an old Onan 6.5 NH so I'm look at other options. I need around 7000 watts. Any opinions on the EU7000i for cold weather use down to around 10 below farenheit? I'm not strong enough to carry a 7000 indoors to warm up every time I need to start it like I did with my other Honda generators.
Old 09-03-2018, 01:22:21 PM
AlexV AlexV is offline
Honda sells cold weather kits for their generators up in Canada. I would give them a call down in Georgia and find out about them. https://powerequipment.honda.com/support/contact-us
The Following User Says Thank You to AlexV For This Post:
Honda EU7000is Parallel Kit MrRedHat Honda, Yamaha, Kawasaki, Isuszu Generators 38 07-01-2018 04:04:58 PM
Honda Eu6500is Help roadster guy Honda, Yamaha, Kawasaki, Isuszu Generators 7 02-19-2018 07:14:41 PM
Honda EU6500is NOOB Hard Starting Question DGKula Honda, Yamaha, Kawasaki, Isuszu Generators 14 08-09-2016 09:24:20 AM
Honda EU6500IS no AC output TaprackFire Honda, Yamaha, Kawasaki, Isuszu Generators 5 02-13-2016 10:34:11 PM
Honda EU6500is Model Number for Parts? DGKula Honda, Yamaha, Kawasaki, Isuszu Generators 1 12-14-2015 12:24:57 PM
