Niphan? Circa 1917 Fittings
this thread has 1 replies and has been viewed 557 times
Old 08-18-2018, 06:18:43 AM
grumit grumit is offline
Default Niphan? Circa 1917 Fittings
hello,i am restoring part of general haigs headquarters train used in france in 1917/18,LNWR 155,there were electric and telephone cables running along the 14 carriage train and i am trying to find a source of electrical fittings catalogues (Niphan ?) that may have pictures of the hook up cable fittings that would have been on the end of the carriage to join all the different carriages wiring together,if i can see a catalogue i can work out what was likely to have been fitted and then find some fittings,they are only for show so a 3d scan would be enough and i get them printed,if you have anything that may be of help or can you suggest a source it would be appreciated,thanks,tony trude
Old 08-20-2018, 05:27:09 PM
Pete Deets Pete Deets is offline
Default Re: Niphan? circa 1917 fittings
Hello Tony,
Sounds like quite a fun project. I would also suggest you try posting the same question at www.rypn.org . In case you're not familiar with them it is Railway Preservation Network and may also be able to help.........PD
Tractomotive circa 1862 20 Reeves Highwheeler Steam Stationary Engines, Traction Engines, Steam Boats 13 09-27-2013 12:03:56 AM
Galloway 5h circa 1908 Ihorse Antique Gas Engine Discussion 6 02-21-2012 09:07:08 PM
Palmer 12 hp - circa 1917 video Ihorse Antique Gas Engine Discussion 4 11-20-2011 12:45:13 AM
Silent Alamo Light Plant - circa 1917 OldIronMan Delco and other Low Voltage DC Light Plants 6 04-01-2008 03:46:25 PM
Tecumseh: HM80 (circa '79) Thierry M. Petersen Small Air Cooled Gasoline Engines 13 04-10-2007 12:26:27 AM
