Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Lighting Fixtures, Switch Panels and Meters
Lighting Fixtures, Switch Panels and Meters Antique lighting fixtures, bulbs, switches, meters and controls.
Heavy Marbel Panel with crank handle & brass contacts
this thread has 5 replies and has been viewed 1887 times
Old 02-13-2016, 09:28:06 PM
Jim Martin's Avatar
Jim Martin Jim Martin is offline
Default Heavy Marbel Panel with crank handle & brass contacts
Does anyone know what this is? Its heavy, made of Marble and has brass contacts on the front & coils in the back? Possible a welding switch/handle?
ID:	246344   Click image for larger version
ID:	246345   Click image for larger version
ID:	246346   Click image for larger version
Old 02-13-2016, 09:39:51 PM
Vanman Vanman is offline
Default Re: Heavy Marbel Panel with crank handle & brass contacts
I'd be inclined to say that it is a manual motor starter for a direct current motor.... Resistance is used to limit armature current to a safe value during acceleration, and is cut out in steps as the motor accelerates.
That's very cool, by the way.
Keith
Old 02-13-2016, 10:45:18 PM
Jim Martin's Avatar
Thanks Vanman, I didnt give the measurments but its 18"s wide and 24"s tall and weighs over 50 pounds.
Old 02-14-2016, 08:02:33 AM
Elden DuRand's Avatar
Images: 11
Since it looks like there were meters mounted on the panel, I'll venture a guess that it's a generator field rheostat and the meters were a voltmeter and an ammeter.
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
The Following 2 Users Say Thank You to Elden DuRand For This Post:
Old 02-03-2017, 08:36:28 PM
ShaneZahn ShaneZahn is offline
My opinion is, its an early D.C. Elevator, control.
Marble & Brass equal Art Deco 1920
Old 02-04-2017, 12:17:47 PM
Frank DeWitt Frank DeWitt is offline
I agree with this. I have seen 1920 DC Motor starters in use, They had no meters. This looks like it had two meters, and perhaps two switches. (Upper right and upper left.) Also I think the fuse holders on the back point to a generator.
Frank
IHC LA LB 1 1/2-2 1/2 HP Brass Handle Flywheel nebbie99 Smokstak Canada 1 11-30-2014 11:41:07 AM
Starting crank handle Id wooden handle Matt1931 Antique Gas Engine Discussion 3 07-29-2013 06:49:17 AM
1945 IHC LB 1 1/2 brass handle wielenberg123 Antique Gas Engine Discussion 6 01-12-2011 07:40:22 PM
How to Handle a heavy piston! David M. Lyon Antique Gas Engine Discussion 10 10-22-2010 07:12:04 PM
IHC LB brass cranking handle question David Babcock Antique Gas Engine Discussion 13 06-22-2010 10:03:31 PM
