Cletrac W Project to be Started
this thread has 24 replies and has been viewed 2943 times
Old 12-22-2017, 07:56:09 AM
AndyMoravec AndyMoravec is offline
Default Re: Cletrac W Project to be Started
I see someone converted yours to lever steer as well. the tractor I bought as a parts downer was converted. I prefer the steering wheel personally. I see you have a part at the front of the engine in one of those pictures that I am missing. It looks like some of the pluming for the air cleaner. have any other pictures of that? I will have to build a new one.
The Following User Says Thank You to AndyMoravec For This Post:
Old 12-22-2017, 08:15:48 AM
Here is the most recent adventure. bolting on rubber pads so I can run in concrete. should be so quiet when I'm done, you wont even hear it coming.
ID:	298768   Click image for larger version
The Following 3 Users Say Thank You to AndyMoravec For This Post:
  #23
Old 12-22-2017, 08:39:59 AM
cletracker cletracker is offline
Yes it has been converted, I have some parts to get it back to original but not all. Not sure if the air tube is original or not. They did have a few different air cleaners if I´m not wrong.
/Erik
Old 12-22-2017, 08:56:59 AM
Correct. They changed over the years. Mine is a 1920. its in the early days when they had a pre-cleaner up near the radiator that strained the air before it went into the air washer and then into the carb. I am missing the Air washer, so if anyone has a spare one of those lying around, send me a message. otherwise I am going to convert the sheet metal so it does not have the air washer option.
  #25
Old 01-05-2018, 03:25:15 PM
Spent some time in the shop over the holidays and got the frame and some track components cleaned for priming. It wont be long till final coat starts getting applied and more parts find their way into the booth.
ID:	299821   Click image for larger version
ID:	299822   Click image for larger version
ID:	299823   Click image for larger version
The Following 4 Users Say Thank You to AndyMoravec For This Post:
Cletrac F Crawler Project ttyR2 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 10-20-2013 07:34:48 PM
Huber project started 20advance Steam Stationary Engines, Traction Engines, Steam Boats 22 02-24-2013 07:43:05 PM
Cletrac EG Project Adam Hartz Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 10-11-2012 12:50:07 PM
Started a new project flywheelphil Antique Gas Engine Discussion 0 06-30-2012 09:56:54 AM
The project has been started IronCity2006 Antique Gas Engine Discussion 1 02-11-2009 01:51:14 AM
