Build a Baker ◊ 2
this thread has 11 replies and has been viewed 3582 times
Old 03-22-2017, 08:13:23 PM
Super4 Super4 is offline
Default Build a Baker ◊ 2
The only thing better than restoring a Baker is to do two of them.
ID:	278234   Click image for larger version
ID:	278235   Click image for larger version
ID:	278236   Click image for larger version
Old 04-19-2017, 07:57:44 PM
Default Re: Build a Baker 2
So,we had a bit of a learning experience, it seems that the bolt pattern on a Wisconsin D 2 (5 1/4 bore)engine is different than on a D 3 (5 1/2 bore). Unfortunately, I only have a D 3 head. Any one out there in Stakker Land have a spare. D 2 head on the shelf?
ID:	281600   Click image for larger version
The Following 3 Users Say Thank You to Super4 For This Post:
Old 05-05-2017, 09:43:01 PM
While we figure out how to solve our piston dilemma, it seemed prudent to attack another challenge. This Baker came without the steering mechanism, but the parts tractor had the housing and crosspiece, but was missing the internal parts. Fortunately Baker 1 has a complete assembly,so we had some patterns to copy. This is a very unique steering actuator that I have not seen on any other tractor.
Old 05-05-2017, 09:49:21 PM
ID:	281533   Click image for larger version
ID:	281534   Click image for larger version
ID:	281535   Click image for larger version
The Following 6 Users Say Thank You to Super4 For This Post:
Old 06-26-2017, 08:43:05 PM
A couple of updates in the Baker steering fabrication.
ID:	285347   Click image for larger version
ID:	285348   Click image for larger version
The Following 7 Users Say Thank You to Super4 For This Post:
Old 08-16-2017, 09:59:41 PM
A few updates of the Wisconsin Baker progress.The newly fabricated steering is complete. Great innovation and work by Rich VerBridge.
ID:	288802   Click image for larger version
ID:	288803   Click image for larger version
Old 12-16-2017, 10:10:46 PM
Default Baker Build
I couldnít find my previous posts, so Iím starting a new one.The first head we were going to try flunked the magna flux test. The head shown had an ugly patch on it,so I ground it off and cut it back to solid material. Hopefully this one will check out. It needs seats and guides. Both heads that came with the tractor look like they were salvaged from the bottom of the sea. A pic. of the new inner bull gear covers, and bull gears from the parts tractor.
ID:	298486   Click image for larger version
ID:	298487   Click image for larger version
The Following 9 Users Say Thank You to Super4 For This Post:
Old 12-16-2017, 11:32:29 PM
Question Re: Baker Build
You now have three Baker threads here, this one, https://www.smokstak.com/forum/showthread.php?t=162972 and https://www.smokstak.com/forum/showthread.php?t=167215
If these are all the same tractor how about I merge them into one thread so everyone knows where it is?.......
The Following 3 Users Say Thank You to Craig A For This Post:
Old 12-17-2017, 02:08:58 AM
greysteam24hp greysteam24hp is offline
Email Over Quota
Images: 100
Default Re: Baker Build
Super4 I'll show you the easy way to your thread forum back. Look at top right of smokstak page after you log on. Yours should comes up that says
Welcome, (Super4) is your id. Next click your id Super4 for next page. When you see it says Visitors messages, about me, statistic then click on statistic will get you there then click again that says Find all threads started by Super4. This will give you all threads you started. This is very nice to find thread forum you want to get back on same track. Hope this helps with your search
Old 12-18-2017, 09:29:56 PM
Baker Tweaking is one project, the other posts can be merged to the second project. Thanks
---------- Post added at 08:29:56 PM ---------- Previous post was at 08:27:21 PM ----------
Thanks, líll give it a shot.
The Following User Says Thank You to Super4 For This Post:
I want to build one!!! greysteam24hp Steam Stationary Engines, Traction Engines, Steam Boats 3 11-04-2015 06:02:32 PM
Should I build one of these? oldtractors Steam Stationary Engines, Traction Engines, Steam Boats 7 07-10-2014 11:37:39 AM
Want to build... tylergig Steam Stationary Engines, Traction Engines, Steam Boats 3 11-27-2005 10:12:59 PM
