Hart Parr 18-36 Project Advice?
this thread has 37 replies and has been viewed 4503 times
Old 05-19-2017, 07:57:34 AM
AndyMoravec AndyMoravec is offline
Default Hart Parr 18-36 Project Advice?
Hello all, I recently started working on my Hart Parr 18-36 and have run into some issues I could use advice on.
the end bearing of the cam shaft has a "sholder bolt" cast into it in which the eccentric for the oiler turns on. that stud has broken off and I have found a replacement. I am not sure how this end bearing comes off however. I cleaned up the gear on the end and it does not look like this can be removed from the shaft. does the bearing slide over it?
any help on how to get the old one out and the new one in would be great.
Thanks!
Old 05-19-2017, 09:14:44 AM
Mitch Malcolm Mitch Malcolm is offline
Banner Sponsor
Default Re: Hart Parr 18-36 Project advise?
I believe that gear is threaded in Left hand threads....
The Following 2 Users Say Thank You to Mitch Malcolm For This Post:
Old 05-19-2017, 09:52:06 AM
Awesome. I will take a look at it tonight and see if that is the case.
Old 05-22-2017, 10:40:03 AM
That did work and I was able to get the bearing out.
Now onto my next issue. anyone know why on a Madison Kipp oiler, that a single line would fill up the cup instead of pumping?
Its acting like the line is plugged but oil does come out the other end every once and a while... not sure how to fix this.
any thoughts would be great.
Old 05-22-2017, 02:58:22 PM
David Babcock David Babcock is online now
Question Re: Hart Parr 18-36 Project advise?
Somebody must have had that pump off and got a tooth out of time re assembling it. Db.
Old 05-22-2017, 05:53:41 PM
Banner Sponsor
Default Re: Hart Parr 18-36 Project Advice?
take the line off on the bottom end and puke a #14 insulated wire thru the line it acts pluged
Old 05-22-2017, 09:31:19 PM
Gene Williams Gene Williams is offline
It is possible to put the eccentric in wrong causing pumps not to work but I would think yours is OK since half of it pumps. I do see a gap in the lower part of the picture so maybe take a look. I think you have an obstructed tube though.
Old 05-22-2017, 10:19:17 PM
Sometimes if you turn up the adjuster all the way, and then pump the heck out of it, you can get it to clear itself. Otherwise, they are not that hard to work on, just fidgety things.
It might be worth pulling it apart to clean up all the pumps, inner passages, uptake screens, etc..
Old 05-23-2017, 05:04:48 AM
RoFoCo RoFoCo is offline
Hi Andy
There's a MK 50 fitted to my 1918 IHC Titan. It's well worth pulling the lubricator apart and thoroughly cleaning it, as it's such an important piece of kit.
Mine appeared fine, but worked so much better after it was cleaned and properly adjusted.
It's also interesting to see how it works, particularly as many of its patents are from Victorian times.
Roger
Old 05-23-2017, 06:45:07 AM
I will give that a try but I don't think it is plugged.
| cleaned out the cup of oil and sprayed brakeclean down and tried pumping and it pumped out the breakclean like normal. Then tried it again with oil and it pooled in the cup again. I am using normal 10w-30 oil so I don't believe that is the issue but I will try to tear it apart a bit more. hopefully I can get it to take oil and try starting it as soon as I get the Mag back.
New Project Hart Parr 12 - 24 Jake OHara Smokstak Down Under 8 04-06-2017 07:38:19 PM
New Project Hart Parr 12 - 24 Jake OHara Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 03-25-2017 12:39:55 AM
1925 Hart Parr 16-30E next long term project E27N Smokstak Down Under 18 09-27-2012 07:04:32 AM
Hart Parr 12-24 Engine Advice/ Tips poolguy Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 08-01-2012 09:59:06 PM
Hart-Parr Oil King Project JT Buice Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 19 09-28-2010 11:09:35 AM
