Aultman Taylor 30-60 Sn2467
this thread has 4 replies and has been viewed 1742 times
Old 11-27-2017, 08:52:14 AM
Reeves13hp's Avatar
Reeves13hp Reeves13hp is offline
Card Sponsor
Default Aultman Taylor 30-60 Sn2467
As you all may know this tractor sold a few weekends back in Jerseyville Illinois and came to itís new home in Missouri. Over the weekend we had the chance to give it a good much needed bath to wash off the very thick layer of old grease and oil.
As some of you may know this tractor has had its lubricators changed out at some point in its like from the original Detroitís to Manzels. Although to us it didnít appear to be just a farmers quick fix. Someone took a lot of time to do it right. Making new brackets, adding check valves on the gear Oiler lines, not disturbing the original engine oil lines, and we wonder at this point if this is when they added 5 big cast iron grease cups behind the engine that grease the counter shaft and differential.
After washing we found a brass tag on the RH cylinder jug. It states
Block Reground
By
Hollarbush Machine Co
Huron, S. Dak
Order parts by #362
So we found this very interesting. After a few google searches all we could really find is old newspaper adds Advertising Hollarbush Machine Co. So we were curious if anyone else had any insight or had ever found a similar tag like this. We also wonder if this company changed the lubricators and added the grease cups at the same time.
Enjoy the pics
Chris
ID:	297123   Click image for larger version
ID:	297124   Click image for larger version
ID:	297125   Click image for larger version
8-1/2x10 Frick
13hp Reeves
50hp Case
22hp Wood Brothers
18hp Advance
20-75 Nichols & Shepard
20hp Corner Bracket Advance
16hp Minneapolis
Old 11-27-2017, 11:05:16 PM
Gene Williams Gene Williams is offline
Default Re: Aultman Taylor 30-60 Sn2467
Not to derail the thread about your tractor but your tractor must have been watched by ours as it went up the assembly line. Ours is 2479. You have a real nice one.
The Following 2 Users Say Thank You to Gene Williams For This Post:
Old 11-28-2017, 12:01:33 AM
Reeves13hp's Avatar
Card Sponsor
Gene that is neat do you no what year they were built ? and both tractors hale from South Dakota. the A&T catalog says Watertown S.D. was a branch and service station. They could of road the same train. have you ever heard of Hollarbush Machinery in Huron ? Could you post some pictures of yours? thanks David
8-1/2x10 Frick
13hp Reeves
50hp Case
22hp Wood Brothers
18hp Advance
16hp Minneapolis
Old 11-28-2017, 09:37:05 AM
Ours has 1917 stamped on the rear axle, it is underneath in the middle not on the end. Our tractor originally came from Beulah ND but is now in SD. I have never heard of Hollarbush Machinery but we are in western SD but I will check with relatives in the Huron area. There are some Youtube videos under chargerkid5 that you may enjoy.
The Following User Says Thank You to Gene Williams For This Post:
Old 12-22-2017, 04:23:26 PM
Reeves13hp's Avatar
Card Sponsor
Made the new water pump shaft today
ID:	298788   Click image for larger version
8-1/2x10 Frick
13hp Reeves
50hp Case
22hp Wood Brothers
18hp Advance
16hp Minneapolis
The Following 8 Users Say Thank You to Reeves13hp For This Post:
Aultman Taylor Maier Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 09-13-2016 04:21:01 PM
30-60 Aultman Taylor Ed Dina Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 08-15-2009 09:41:54 AM
170 Aultman taylor Jeff W B Steam Stationary Engines, Traction Engines, Steam Boats 50 06-23-2007 11:29:07 PM
Aultman & Taylor Mike in NC Steam Stationary Engines, Traction Engines, Steam Boats 0 05-03-2005 10:15:56 PM
30-60 Aultman Taylor Bruce Flatmoe Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 11-19-2004 03:39:47 PM
