John Deere 10 Spline Axle Vs 12 Spline!
this thread has 2 replies and has been viewed 912 times
Old 12-27-2017, 01:14:54 PM
tomcat211 tomcat211 is offline
Default John Deere 10 Spline Axle Vs 12 Spline!
Looking for a little guidance here! My son and I dug out our late grandfathers 1937 JD un-styled A to restore. We've been at it for 1 1/2 years now and are in the final stretch! ( I thought!!) See when we dug it out it was on a set of solid discs rims, while restoring it we had planed on using a set of spoke rims when finished. Small issue! although we have 6-7 pair of different spoke rims- all of them take a 10 spline axle! as you might guess the tractor we restored has 12 spline axles.
So my question! Is it worth swapping the Axles to use the spoked rims or should we leave the 12 spline axles on it and use the org. rims and tires? looking on the internet it seems the 12 spline is a bit more rare and harder to find, making me wonder if we should use leave them on it.
Thoughts please!!
Name:	toms cell phone 103.jpg
ID:	299088   Click image for larger version
Name:	toms cell phone 106.jpg
ID:	299089   Click image for larger version
Name:	toms cell phone 017.jpg
ID:	299090   Click image for larger version
Name:	toms cell phone 018.jpg
The Following 4 Users Say Thank You to tomcat211 For This Post:
Old 12-27-2017, 09:25:33 PM
Ken Majeski's Avatar
Images: 46
Default Re: JD 10 spline axle VS 12 Spline!
I believe the 37 A that I had did have 10 spline axles. So they probably would be correct for yours.
One thing I did run into with a B that I messed with many years ago is the Bull Gears were different also. So there is a possibility you would have to change them also.
Ken Majeski, Ellsworth Wis.
The Following User Says Thank You to Ken Majeski For This Post:
Old 12-28-2017, 02:30:17 AM
OldThresherM OldThresherM is offline
Default Re: John Deere 10 Spline Axle Vs 12 Spline!
Based on what I've managed to decipher,12 spline axles ran from #460000 to #487999 - Late '37 through '39.They are a bit harder to find,however I believe there are a couple sets on ebay right now.Also,Pat Detwiler may be a good person to contact.He is well known here on the stak.Maybe he could work up a trade with you.
The Following 2 Users Say Thank You to OldThresherM For This Post:
John Deere H axle bearings Mike Schweikert Antique Farm Tractors 0 06-13-2017 10:54:55 AM
John Deere D wheel spline repair? OldThresherM Antique Farm Tractors 7 08-24-2014 10:48:10 PM
Six Spline JD D axles and hubs JoeCor Antique Farm Tractors 1 01-03-2013 04:59:12 PM
JD - D wheel hub spline to axle spline fit G502 Antique Farm Tractors 2 01-11-2010 01:41:24 AM
Stuck Spline Shaft P Stier Antique Gas Engine Discussion 3 08-23-2005 11:51:20 AM
