Leroi 2C Motor Diagrams
this thread has 6 replies and has been viewed 714 times
Old 12-27-2017, 02:30:22 PM
Paul Searl's Avatar
Paul Searl Paul Searl is offline
Default Leroi 2C Motor Diagrams
Does anyone have a cutaway view, diagram or parts plates for a Leroi 2c motor used in the Indiana, AC 6-12, Bailor, IHC & Heider motor cultivators and a large number of other machines? Especially looking for something showing the oil pump. I thought I had something saved, but for the life of me I can't find it and the little printed material we have on the engine shows nothing.
Old 12-27-2017, 02:36:59 PM
Card Sponsor
Default Re: Leroi 2c motor diagrams
I have a couple of 2c's here Maybe I could measure something for you. Rob
Old 12-27-2017, 02:52:14 PM
Paul Searl's Avatar
Rob, thanks. We actually have a couple of them ourselves and one of them the isn't working pumping oil. Before dad starts tearing into it he was hoping to find some diagrams to get an idea of what else could be the issue and what the oil pump should look like. We've never had the bottoms of these engines apart.
Old 12-27-2017, 05:26:57 PM
Kent McMakin Kent McMakin is offline
Default Re: Leroi 2C Motor Diagrams
Paul. Got a copy of a Le Roi L head engine instruction manual that covers the 2C if that would be of help.
The Following User Says Thank You to Kent McMakin For This Post:
Old 12-27-2017, 10:57:54 PM
Paul Searl's Avatar
That might help, we might have the same thing. our copy has no engine diagrams or anything in it though.
Old 12-28-2017, 09:54:55 AM
Card Sponsor
I've had the oil pump apart. It has check balls in it maybe yours is all gummed up. The engines here have an external plunger type oil pump which operates from a lobe on the cam Rob
The Following User Says Thank You to Rob Charles For This Post:
Old 01-14-2018, 04:37:25 PM
Paul Searl's Avatar
for future reference, here is the pump. we were overthinking it and hadn't realized it was an external type.
ID:	300497   Click image for larger version
ID:	300498   Click image for larger version
ID:	300499   Click image for larger version
Wiring diagrams needed hlflorek Onan Generators 4 12-03-2015 11:24:26 PM
looking for a couple wiring diagrams GHanners Onan Generators 1 06-15-2012 04:29:44 PM
201,226 leroi motor bcpuller Machine Shop and Tool Talk 0 08-31-2010 09:15:51 PM
Lincoln SAE-300 Diagrams? Holland501 Welding Shop 2 06-12-2007 12:24:18 AM
LeRoi Company Donkey Motor midpw Antique Gas Engine Discussion 0 05-31-2005 09:31:35 AM
