18-36 Hart Parr Radiator Extension
this thread has 6 replies and has been viewed 788 times
Old 01-01-2018, 10:14:11 PM
MSimons's Avatar
MSimons MSimons is offline
Card Sponsor
Default 18-36 Hart Parr Radiator Extension
I recently found what I believe is an 18-36 Hart Parr radiator with an extension. It looks to be factory. I had assumed it was for a power unit but the parts book I have only lists an extension for tractors (Part # 13204). This radiator also has a tin fan shroud that I haven't seen before. Can anyone tell me about these? Thanks in advance.
ID:	299558   Click image for larger version
Old 01-02-2018, 10:19:41 AM
Autotrac Autotrac is offline
Default Re: 18-36 Hart Parr Radiator Extension
Maybe it's a retro fit for the early 28-50s before they got the big rad??
The Following 2 Users Say Thank You to Autotrac For This Post:
Old 01-02-2018, 09:15:34 PM
MSimons's Avatar
Card Sponsor
That thought had crossed my mind as well. But I wonder why is it listed in the 18-36 parts book?
The Following User Says Thank You to MSimons For This Post:
Old 01-02-2018, 09:37:46 PM
Dave Preuhs Dave Preuhs is offline
I've never seen the radiator extension before, I will have to check my parts too. Maybe it was something they used on tractors for hotter climates???? Or at least had it available to sell. Have you checked any other model to see if they had rad extensions?
The Following User Says Thank You to Dave Preuhs For This Post:
Old 01-02-2018, 09:41:46 PM
MSimons's Avatar
Card Sponsor
Hi Dave,
I only have an 18-36 parts book so that is the only one I was able to check. Would appreciate hearing what you find.
Michael
Old 01-02-2018, 10:26:44 PM
halcon halcon is offline
Possibly when burning low cost fuels and using a lot of combustion water they found they didn't have enough water on board as they used it out of the cooling system. With Hart-Parr's high mounted water pump allowing it to run low could cause the pump to loose its prime.
The Following 3 Users Say Thank You to halcon For This Post:
Old 01-02-2018, 10:30:52 PM
Hi Dave,
Michael
Michael, I tried looking in the 12-24 book but couldn't find anything like that, maybe I missed it too. I did find that part number in the 18-36 book so it must be authentic, can't be many of those around. By time HP figured out the 22-40's and early 28-50's had a heating problem they came out with the big radiator 28-50.
18-36 hart parr Hezekiah Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 06-09-2015 08:10:32 PM
Hart Parr help... jim burlingham Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 07-17-2011 09:47:04 PM
30-60 Hart Parr's Chris Epping Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 06-03-2011 11:49:20 PM
Hart Parr 18-36 prkohlwey Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 05-02-2011 09:58:59 PM
18-36 Hart Parr Phil Johnson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 03-29-2009 11:37:14 AM
