International 8-16
this thread has 23 replies and has been viewed 2658 times
Old 01-02-2018, 08:03:01 PM
Okeemark Okeemark is offline
Default International 8-16
Im working on a 8-16. From my understanding, there was 3 different engine combos. Not sure which one i have. Im looking for a exhaust manifold and a source for parts. Tractor is complete and was told it has ran recently but i have not had it running yet. What should be looked for to figure out what engine this machine has. Attached is a picture of manifold. Its broke in 3 spots, 2 cracjs and one complete break. Any info would be much appreciated, Thanks
ID:	299617   Click image for larger version
ID:	299618   Click image for larger version
ID:	299619   Click image for larger version
The Following User Says Thank You to Okeemark For This Post:
Old 01-02-2018, 11:32:24 PM
Butch Howe Butch Howe is offline
Default Re: International 8-16
1918 series VB has a chain drive oiler on right side of the engine. Mid 1919 series HC did away with the oiler and added a water wash air cleaner. 1921 series IC bigger engine 284 cu in. Until end of production 1922.
Difficult to find parts as there were 3 different engines in 4 years. A handful of Stackers have 8 16s including myself. Search this site quuite a lot of info.
You may be able to fabficate a manifold until a corre ct one can be found.
The Following 3 Users Say Thank You to Butch Howe For This Post:
Old 01-02-2018, 11:55:56 PM
By these pictures, would there be a way to identify which model this is? This way i would have a better idea of which manifold to look for.
Old 01-03-2018, 12:47:44 AM
Welcome to STAK Okee.
I moved your thread to the OTHER tractor forum.
Old 01-03-2018, 09:00:43 AM
Kevin A. Behnke Kevin A. Behnke is offline
Tractor ser. number is stamped by the magneto on the engine. This will ID what you have. Kevin
Old 01-03-2018, 11:06:52 PM
D Rutherford D Rutherford is offline
I believe yours to be a HC model as it looks like my HC 1054 sn the carburetor intake is all the same, best of luck
Old 01-04-2018, 11:36:47 AM
K Cooke K Cooke is offline
There should be a boss right by the mag with ID No. but to me its an HC. Ealier models had an oiler later models exhausted out he side of the hood. Later models also had the fuel tank bracket solid not strap steel like yours
Old 01-04-2018, 02:16:53 PM
oldironlindy oldironlindy is offline
I have repaired manifolds that are worse than that. find someone with a nickel powder torch that knows what they are doing and it can be repaired. Nice tractor by the way!
---------- Post added at 12:16:53 PM ---------- Previous post was at 12:13:37 PM ----------
https://www.youtube.com/watch?v=71amiAPXBn0
Old 01-04-2018, 02:44:19 PM
bschrum bschrum is offline
Repair it. I, like another person have repaired castings worse than this. I used stitch pins from Lock-n-stitch. They are somewhere in California and provide the supplies and assistance to use the product. It is a little spendy ut the process sure does work good. My last repair was on a cylinder head that froze nearly breaking the entire end off the head. it was on a 1944 V-12 engine that was very tough to find parts for (at least nothing that wouldn't cost less than several thousand dollars) so I used this process with excellent results.
The Following User Says Thank You to bschrum For This Post:
Old 01-04-2018, 02:58:46 PM
We fixed worse manifolds than that one the old fashioned way: gas welded with pure gray iron rod.
International UD-14 Snowplow Dog Vintage Diesel and Oil Engines 27 02-22-2016 10:30:53 AM
International LA won't run petrj6 Antique Gas Engine Discussion 17 01-04-2015 03:46:11 PM
International Cub rawpower2 Antique Farm Tractors 5 08-23-2014 10:59:53 AM
International M ? CLowe Antique Gas Engine Discussion 7 06-29-2008 08:47:05 AM
International LB Mitch Basich Antique Gas Engine Discussion 7 04-18-2005 06:15:48 PM
