Oil Pull 30-60 Engine Info. Needed
this thread has 1 replies and has been viewed 597 times
Old 01-04-2018, 02:33:24 AM
Hank Smith Hank Smith is offline
Question Oil Pull 30-60 Engine Info. Needed
Our museum in Cave Creek AZ is looking into restoring an Oil Pull 30-60 Stationery engine built in 1911 that powered a gold-stamp mill in the early 1900's. We know that we need a carburetor and magneto among other things. Any help that you can give us will be so appreciated.
Thanks, Hank
Old 01-04-2018, 11:55:28 AM
Ross Clarke's Avatar
Ross Clarke Ross Clarke is offline
Images: 22
Default Re: Oil Pull 30-60 Engine Info. Needed
Hello Hank
That would probably be a heavy weight engine.
I have attached a pic of one that I saw in Forest City IA this year.
If you search on You Tube there is some video of this one running at another show.
Good luck on your search for parts.
Do you have the stamp mill?
That would be an impressive display if are able to get it all running.
I have also sent you a private message.
Ross
The Following User Says Thank You to Ross Clarke For This Post:
Rumely Oil Pull Parts Identification Needed Ironman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 11 01-02-2018 07:30:57 PM
Info needed on this engine Gary Bahre Small Air Cooled Gasoline Engines 3 09-26-2010 09:58:59 PM
B/S conversion from pull to elec start info B n G Garden Tractors / Mowers / Scooters 1 03-25-2009 08:45:47 AM
engine info needed Mark C. Flewelling Antique Engine Archives 2 11-08-2003 09:33:16 PM
Hot Air Engine Info. needed WA. larry hughes Antique Engine Archives 0 02-26-2002 12:01:59 AM
