McCormic Deering 22-36
this thread has 6 replies and has been viewed 774 times
Old 01-08-2018, 07:58:15 PM
retired wrench retired wrench is offline
Default McCormic Deering 22-36
As a youngster it seems I remember a 22-36 with 3 tanks and 2 carbs. Am I dreaming?
The Following 3 Users Say Thank You to retired wrench For This Post:
Old 01-08-2018, 11:40:46 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Default Re: McCormic Deering 22-36
Yes if it was set up to burn on kerosene.
Old 01-09-2018, 12:16:03 AM
Thanks for the reply. I thought I was remembering right but have seen others that weren't that way.
Old 01-09-2018, 09:44:29 AM
Russ Hamm's Avatar
Images: 1
My favorite tractor. The two carbs you remember were actually one but it had a water bowl attatched off to the side. One small gas starting tank, one large kerosene tank and one water tank for water injection when burning kerosene.
The Following 3 Users Say Thank You to Russ Hamm For This Post:
Old 01-09-2018, 10:54:21 AM
Thank you. I ran this one doing some dirt work 70 years ago but none I have seen since had this set up so I was doubting myself.
Old 01-09-2018, 03:26:08 PM
FWurth's Avatar
One Millionth Post
Images: 4
When the heavy tractor fuel fell out of favor, most of those old units were converted to burn gasoline. They would put on a cold manifold and a better carb to start with. Crank up the revs and they could get around 50 hp out of them.
Old 01-09-2018, 11:49:13 PM
I think we quit using distillate around 1950. Well thanks for the info all.
The Following User Says Thank You to retired wrench For This Post:
McCormic - Deering 1-1/2HP Newstar Antique Gas Engine Discussion 4 07-22-2014 07:53:01 AM
McCormic Deering One and a Half HP M DustyEngine Antique Gas Engine Discussion 0 04-12-2012 11:40:50 AM
3-5hp McCormic Deering TheToolman Antique Gas Engine Discussion 6 06-20-2008 07:08:32 AM
McCormic-Deering W12 Rob Karl Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 09-05-2006 08:13:23 PM
McCormic Deering Bryan Antique Engine Archives 1 04-24-2001 07:00:11 PM
