Homelite EZ6 Chainsaw
this thread has 4 replies and has been viewed 890 times
Old 08-07-2017, 10:24:23 PM
chainsaw mechanic chainsaw mechanic is offline
Default Homelite EZ6 Chainsaw
I recently bought a homelite ez6 chainsaw that is in really good condition but does not run the hole that the petcock screws into the gas tank constanly gets clooged because the tank has so much rust and varnish I could probably make pound cake with it DOES ANYONE KNOW A METHOD TO CLEAN A GAS TANK REALLY GOOD BECAUSE MINE IS GONNA NEED SOME TLC
Old 08-08-2017, 05:13:42 PM
Russell Walker Russell Walker is offline
Default Re: homelite ez6 chinsaw
Add mineral spirits and a bunch of 1/2" ball bearings and ride it around in the back of your truck for a few days and keep turning it over/switch positions.
The Following 2 Users Say Thank You to Russell Walker For This Post:
Old 08-08-2017, 10:18:30 PM
Acetone or MEK will really cut that stuff. Yep,just ride it around in the truck a while with the ball bearings and liquid.
Old 08-08-2017, 10:43:43 PM
I've bungee corded fuel tanks to a rear tractor wheel, put a handful of 3/8 nuts and bolts in it and drive around to check the cows. may take several trips but it knocks a lot of crud loose. I was always afraid to run anything volatile in the tank but I did try pine sol and it helped some.
all the rattling around kinda freaked the cows out tho.
Old 02-02-2018, 11:22:06 PM
oologahan oologahan is offline
Red Kote sealant will coat the inside and repair leaks at the same time, made for gas tanks
homelite ez6 chainsaw chainsaw mechanic Chain Saw Collectors 0 08-08-2017 03:55:52 PM
Homelite BUZ Chainsaw Gaskets Steveoh Chain Saw Collectors 1 04-08-2012 03:26:55 PM
Homelite chainsaw info Duane H Chain Saw Collectors 2 12-31-2007 08:33:53 PM
Homelite chainsaw Alex Chain Saw Collectors 0 10-19-2000 09:09:39 PM
Homelite Superwiz chainsaw Andrew Semeiks Chain Saw Collectors 1 09-08-1999 03:07:26 AM
