Babbitts turning to powder and wont come off
this thread has 1 replies and has been viewed 1313 times
Old 09-09-2009, 08:35:04 PM
Christopher Underwood Christopher Underwood is offline
Default Babbitts turning to powder and wont come off
Hi I noticed that grease wasn't coming out of the bearing on my empire on the crankshaft. when I took the back end of th bearing cap off the babbots wee like dust partially. no grease was getting to the bearing. When I tried to take the babbot and bearing cap off they wouldn't budge at all. How can I get the bearing and babbot off and are they reusable if the powdery stuff is taken off and grease can get to the bearing?
Chris
Old 09-09-2009, 11:15:18 PM
Exclamation Re: Babbitts turning to powder and wont come off
If done right, the babbitts are soldered to the mains. They usually have to be melted out, and re-poured. Is the powder just surface, or they pitted badly? If pitted, replace. If surface, scrape until bare metal exposed, remove high spots (trial & error, with some prussian bluing), Drill out grease opennings, and grease and shim as nescessary. Sounds like either you got water in the soap based axle grease, or mixed soap based grease and parafin based (oil)greases, and it turned caustic, and ate your bearings (BOO-HISS) make sure not to mix your greases!
Clean out all bearings and grease cups, clean out ALL grease thoroughly. After setting the bearings, hand grease shafts and fill grease cups, and turn down caps as crank is rotated. Make sure grease comes out both sides of bearing. Note type and brand of grease AND DON'T CHANGE IT!!!
The Following 3 Users Say Thank You to Andrew Mackey For This Post:
Need New Babbitts Christopher Underwood Antique Gas Engine Discussion 1 08-27-2009 06:26:28 PM
Powder Coating an Engine Doug Waggonner Antique Gas Engine Discussion 10 10-30-2008 05:02:47 PM
Powder coating Tanner Remillard Paint Shop 5 05-23-2005 12:20:48 AM
Powder Coating Brian Ford Paint Shop 9 12-12-2004 11:07:42 PM
powder coating ?? chuck weimer Antique Engine Archives 4 06-02-2004 09:33:20 AM
