Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Solar and Wind Power for Home, Farm & Industry
Solar and Wind Power for Home, Farm & Industry Windmills, solar panels and inverters for standby power.
Dimensions Pure Sine Inverter Powering an inverter directly from the panels
this thread has 16 replies and has been viewed 3893 times
Old 11-16-2014, 01:28:59 PM
4Strokeguy 4Strokeguy is offline
Default Dimensions Pure Sine Inverter Powering an inverter directly from the panels
Hi folks,
I have been wondering if being off the grid can an inverter be powered directly without any battery bank?
My thought here would to use some Ultra or Super Capacitors as a buffer between the panels and the load (inverter). I am pretty sure this could work depending on the inverters internal protection for low or over voltage.
It isn't that I am against using a charge controller and a battery bank. The primary goal is to power refrigeration while the sun is up. The Ultra caps would provide the extra capacity during compressor start up.
Any thoughts on this?
All the best, Craig
Old 11-16-2014, 03:23:44 PM
KeithW's Avatar
KeithW KeithW is offline
Default Re: Dimensions Pure Sine Inverter Powering an inverter directly from the panels
Could work. Might be some issues with peak current, caps will dump a ton of juice. Some stratigic use of long wires could help limit things. On thing you might also do is to use a relay and shut everything down while the panels are not putting out any power. Have the relay kick in once the caps come up to charge energizing the system.
Old 11-16-2014, 04:39:39 PM
Thaumaturge Thaumaturge is online now
Likely wouldn't work unless you have some VERY serious panels. At 100% efficiency -which is never acheived- a 1200 Watt load will suck 100 amps on the input to the inverter. That's a constant load. Even a big bank of super caps would only push that for a few seconds, if that.
Doc
Old 11-16-2014, 05:01:29 PM
KeithW's Avatar
What he said. Except that small fridges don't draw much except at startup. If the panels are sized to provide the run current and the caps were sized to provide startup then it might work. It would be important to keep things shut down until the panels are producing enough to provide run current and the caps are charged. This would be a dedicated system built around keeping the fridge cold. Perhaps not the most efficient but functional given the criteria of not using a battery.
Old 11-16-2014, 09:17:38 PM
Camper Camper is offline
When I worked at one particular RV dealer, some of the trailers that came in and had solar on the roof and a 100 watt inverter for the entertainment center. Not realizing the inverter was on, without the battery on the trailer, the electronics failed from low voltage as the solar panel could not keep up to the demand. I would not take the chance.
Old 11-29-2014, 11:47:05 PM
Thanks to all that have replied, sorry I had not pop in to answer individually.
This project will be on hold until spring. I did get some Maxwell brand "D Cell" Caps, they are rated 350 farads at 2.7 volts DC. believe it or not you can start a 4 liter engine with these alone.
They are not much bigger than a D cell battery. So 6 in series yields 16.2 that should pack enough punch into an inverter on an inrush compressor start?
Old 11-30-2014, 07:04:04 AM
Elden DuRand's Avatar
Images: 11
Be careful when series connecting capacitors to increase the voltage rating.
If the caps aren't perfectly matched, one of them will always be under the most stress and could fail prematurely. If it fails in a shorted condition, there goes the string.
With smaller value capacitors, it helps to place equal value resistors across each cap to help equalize the voltage across each one.
What value of resistance depends on the leakage rating of the caps.
With those huge capacitances, the resistors would probably have to be drawing significant current to do their job, probably in the tens of milliamps.
Good luck and let us know how it goes.
Take care - Elden
http://www.eldensengines.com
Old 11-30-2014, 03:45:09 PM
cornbinder89 cornbinder89 is offline
Originally Posted by 4Strokeguy View Post
Hi folks,
All the best, Craig
If a 'fridge is your goal, LP, NG or Kero 'fridge would do the job and be silent. They cost more then an electric, but I have had one in my truck for going on 20 years, still works as good as new.
Also some absorbsion cycle 'fridge can be run on 12 or 120 volts, it is a straight resistance load, so would be easyer to budget for electric load, if you are set on solar power.
The Following User Says Thank You to cornbinder89 For This Post:
Old 11-30-2014, 03:49:37 PM
I have had a LP gas/electric absorption type refrigerator (ammonia refrigeration) and they do work quite well, most cold storage warehouse use them.
I want to be independent of the fuel cost.
I have converted a chest freezer to a fridge using a Ranco capillary thermostat. Once that box reaches the set point the compressor only runs 5 to 10 minuets per hour. I have yet to turn it off to see how well it will hold that setting over a 12 hour period
Old 11-30-2014, 05:28:53 PM
Well, as I said, many can be had with 12 or 120 heaters as the source of power, and with those there is no "starting factor" to think about, pure resistance. May not be as efficient (I don't know) but when you consider that they can be made to run on any heat source, you could likely replace the heater with any voltage, so no inverter nor any of its in efficancys nor any high starting amps.
Inverter Troubles richard.bessey Solar and Wind Power for Home, Farm & Industry 25 09-25-2015 04:49:37 PM
Sine Wave Inverter & Generator Power Bassplayer1985 Generators & Electric Motors General Discussion 40 10-28-2014 10:30:11 AM
sine wave inverter theory/problems and the relation to audio armandh Generators & Electric Motors General Discussion 2 04-25-2012 10:46:55 AM
8KW Inverter rrfxxxr Generators & Electric Motors General Discussion 7 09-19-2008 10:32:08 AM
Generac 941 Inverter Lupatrian Generac Generators (SEARS, etc.) 1 07-26-2008 12:34:44 PM
