Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Solar and Wind Power for Home, Farm & Industry
Solar and Wind Power for Home, Farm & Industry Windmills, solar panels and inverters for standby power.
Air 30, 400 watt wind generator.
this thread has 6 replies and has been viewed 2977 times
Old 07-10-2016, 01:08:49 AM
Kevin New Mexico Kevin New Mexico is offline
Default Air 30, 400 watt wind generator.
Does anyone work on Air 30's? I was given this one and it will not come out of regulation mode. the brake kicks in at 6.4 vdc and will not kick out. Not sure where to go with this.
Old 07-10-2016, 02:16:37 AM
Default Re: Air 30, 400 watt wind generator.
Post some pics of internals. Right off it sounds like a latched SCR.
"There is always some yayhoo turning left!" - my father.
Old 07-11-2016, 12:10:53 AM
Tring to download some from the net.
ID:	258005   Click image for larger version
ID:	258006   Click image for larger version
Old 07-13-2016, 09:23:21 AM
Okay, while I can't see much very useful on such small shots, one thing I see is three slip rings in the head. Which means not all is lost if you have to discard stock controller. I count twelve poles on gen head. Three slip rings sugest a Delta wired alternator. So easy to just build a three phase recifier diode stack and feed output to cheap solar controller board. Google three phase recification for circuit. Dealextreme (dx.com) has cheapo solar controllers. I paid about $15 for a 30Amp from them.
Optimum would of course be to fix stock controller, as solar controller won't provide for braking.
Doc
Old 07-14-2016, 03:05:00 AM
Okay, I will look into that, that is good information. IF I have to I will buy a replacement controler. Wind out here is really hard some days. The unit needs to brake.
Old 10-23-2016, 08:49:36 PM
stretch67 stretch67 is offline
Breaking is easy as its wild 3 phase coming down with out controller. Just get your self a 3 pole breaker and add a feed off that ever your bridge rectifyer setup.
Run the feed into top of breaker and then jumpers on bottom to the other phases.
Throw the breaker and brake is on.
Old 01-18-2017, 09:20:30 PM
MEPman MEPman is offline
https://www.emarineinc.com/categorie...-Wind-Turbines
these folks have parts
http://primuswindpower.com/maintenan...e/warranty1-2/
here is the owners manufacture
Win-charger, wind generator. 1936JDB Solar and Wind Power for Home, Farm & Industry 19 06-07-2012 02:21:02 AM
Three Phase Motor for a Wind Generator dalmatiangirl61 Solar and Wind Power for Home, Farm & Industry 47 11-07-2011 07:23:22 PM
Sears companion 5000 watt generator needs generator unit daytonakid Generac Generators (SEARS, etc.) 1 05-17-2010 04:21:46 PM
Alternator for Low Wind Speed Wind Turbine Needed mechamz Generators & Electric Motors General Discussion 3 05-22-2008 11:20:05 AM
Alternator for Low Wind Speed Wind Turbine. mechamz Generators & Electric Motors General Discussion 3 05-15-2008 08:16:49 PM
