Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Solar and Wind Power for Home, Farm & Industry
Solar and Wind Power for Home, Farm & Industry Windmills, solar panels and inverters for standby power.
An Interesting Open Source MTTP Charge Controller
this thread has 1 replies and has been viewed 5236 times
Old 03-18-2011, 04:54:12 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking An Interesting Open Source MTTP Charge Controller
Found this, looking around this morning... Interesting project for the electronically handy....
http://www.freechargecontroller.org/...itle=Main_Page
Bruce in alaska
The Following User Says Thank You to BTPost For This Post:
Old 04-07-2012, 04:03:36 PM
Flintstone Flintstone is offline
Default Re: An Interesting Open Source MTTP Charge Controller
Wow Bruce! I just stumbled into some of your stuff. Yea, long time, no grid here ether. I just filed some Bosch brushes, drilled'm to accept a short plug of copper to solder to, and got the Ametek Vacuum? perm magnet hydro gen going at about 60W, (again). With that 24/7 and the solar, like yourself I only need the Onan for the shop normally. I actually have a little Honda 600w that will just run the charger(s), only if the bank isn't hammered, pushen 25-35 Amps.
Spring...too busy BUT, I was toying with the idea of fabbing my own permanent magnet armature, or rotor, using those supper strong, killer (nobidium?) magnets found in old hard drives. They can be purchased as well.
Doing away with brushes (in an alternator), and having convenient, hardy auto bearings would sure make my life easier.
Just to busy now, hydro is going....again, but neat. A series of home baked adjustable shunt type controllers would be pretty sweet. Top the gen battery, then pump water, turn on a fan or a heating element....
Jacktown Mag Charge Horse Power at 511 Magnetos, Ignition Coils and Spark Plugs 3 01-19-2011 02:05:49 PM
Think I can charge a mag with this? Elwood Antique Gas Engine Discussion 5 01-09-2010 11:27:22 AM
Controller Help! jpvaughn Kohler Generators 4 04-10-2009 10:16:31 AM
Charge a Mag for a B&S FI Mike Herbertson Small Air Cooled Gasoline Engines 10 10-09-2005 12:25:24 AM
Need to charge a mag. Fred Shouldice Antique Engine Archives 0 10-29-2002 06:10:13 PM
