Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Solar and Wind Power for Home, Farm & Industry
Solar and Wind Power for Home, Farm & Industry Windmills, solar panels and inverters for standby power.
Electric brake question
this thread has 4 replies and has been viewed 4107 times
Old 12-14-2011, 02:24:47 PM
Yukon Yukon is offline
Default Electric brake question
Will shorting out the wiers on a PMG work as a brake like it does on an alternator?
Old 12-14-2011, 04:09:11 PM
John Newman, Jr.'s Avatar
Default Re: Electric brake question
Yes - But...
If you don't provide someplace for the current to go, you could end up burning out the windings in the generator. I would look into a big resistor that can handle the current rather than just shorting out the generator directly.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 12-14-2011, 11:22:15 PM
Thanks John. I was thinking of using it as a parking brake only.
Old 12-15-2011, 12:46:07 AM
A motor won't work at all as a 'parking brake' because it has to move to generate resistance-it will creep with practically no resistance at a slow speed and increase as the speed goes up.
The Following User Says Thank You to pegasuspinto For This Post:
Old 12-15-2011, 07:45:14 PM
Looks like I have my answer. Quess I will give up on that idea.
Electric question on a Continental 23HP LA Ike Multi-Cylinder Stationary Engines and Power Units 19 07-07-2014 10:21:20 AM
Electric brake maintenance? John Drabik Trucks, Trailers and Hauling for Shows 5 04-30-2008 10:58:27 PM
Trailer brake question 21avery Trucks, Trailers and Hauling for Shows 13 03-18-2008 05:49:44 PM
Onan Electric Plant question GerryL Onan Generators 2 02-09-2005 08:00:54 AM
