Welding Shop
Does this welding transformer look bad?
this thread has 8 replies and has been viewed 954 times
Old 07-11-2018, 02:54:44 PM
SteveL SteveL is offline
Default Does this welding transformer look bad?
So I have a basic 240v single phase ac dc stick welder I bought used about 10 years ago, and I figure it's about 20 years old now. Recently it has started to sort of pulse while welding. It's to the point that you cannot maintain an arc for more than few seconds at most. It seems to be pulsing around ever second or maybe a little quicker. Upon opening it up all I could find were some small bubbles on the winding of the main transformer. In pictures it looks like varnish that has dripped or run but there is no varnish on this transformer anywhere else.
So I'm wondering if this looks like the enamel breaking down?
Thanks in advance --Steve--
ID:	313997   Click image for larger version
Old 07-11-2018, 05:26:01 PM
Default Re: Does this welding transformer look bad?
Those bubbles are from where the varnish cured. So far so good.
Old 07-11-2018, 06:17:43 PM
Looks normal to me. Black and crumbly is when you get nervous.
Old 07-11-2018, 06:21:44 PM
Vanman Vanman is offline
Do the symptoms occur on both AC and DC?
Old 07-11-2018, 08:55:05 PM
Yes it's on ac and dc. But does seem to be less noticable on dc, but still there. I think I could almost manage to maintain the arc on dc where as ac could not. Also I should add there is no electronic pulse or hi freq or anything like that on this machine.
---------- Post added at 08:55:05 PM ---------- Previous post was at 08:53:45 PM ----------
I would think varnish too but there is no sign of it anywhere else, which is why I thought it might be the enamel coating
Old 07-12-2018, 01:10:32 AM
Hmmm... I think I'd look for loose connections then. Both within the machine as well as in its supply circuit. Could even be a breaker with bad contacts.
If the transformer was failing, it wouldn't last long before it made itself readily apparent.
Old 07-12-2018, 01:20:08 AM
Power Power is offline
Concur with Vanman. Also check the cables, connections at welder, and inside stinger.
I once had a corroded connection inside stinger play havoc on my welds.
Old 07-12-2018, 01:34:15 AM
FWurth's Avatar
FWurth FWurth is online now
One Millionth Post
We use our old Lincoln 225 a lot and am on the second set of cables, had to re do the stinger connection the other day and noticed that the copper inside the cable is black from over heating. I had noticed that it has been getting more difficult to start and maintain a good arc lately. I guess I'll have to pony up for new cables again.
Old 07-12-2018, 02:33:55 PM
Ah good point. I'll double check all connections then try again. I'll post results successful hopefully
MIG Welding cobbadog Welding Shop 15 12-22-2017 07:16:57 AM
AC or AC/DC for Welding Shay 5 fan Welding Shop 8 01-18-2012 02:23:13 PM
Welding rod Chris J Welding Shop 7 08-17-2008 10:22:53 AM
Thoughts on crankshaft welding/ engine block welding Mac Leod Small Air Cooled Gasoline Engines 10 04-14-2008 10:46:02 PM
Welding Matt Fretwell Welding Shop 23 10-12-2003 07:35:59 AM
