Welding Shop
1966 Onan CCK-MS/1196g Engine on a Miller Welder
this thread has 10 replies and has been viewed 647 times
Old 04-04-2019, 07:34:27 AM
1989bwood 1989bwood is offline
Default 1966 Onan CCK-MS/1196g Engine on a Miller Welder
I need help on how the ignition system works on my onan cck-ms/1196g. I have everything I need and I have replaced the coil, points, condenser/capacitor, and have confirmed that I am getting power(12volts) to the coil and the points box. Can someone help me out, I still canít get spark and Iím not too familiar with battery ignition systems like this. HELP
Old 04-04-2019, 08:21:43 AM
Esteban32696 Esteban32696 is offline
Default Re: 1966 onan cck-ms/1196g engine on a miller welder
I sent you a P.M.
Old 04-08-2019, 07:15:38 AM
Hi I did not get any messages. Thank you
Old 04-08-2019, 05:54:14 PM
bad coil?
Old 04-08-2019, 09:02:54 PM
I bought a new coil, new points, new condenser, and checked everything else over. I noticed today that my 1.75 ohm 25 watt resistor is bad. Gonna order one of those and see if it works.
Old 04-10-2019, 05:17:55 AM
I had replaced all those ignition parts on mine with Onan parts and it still would not get fire to the plug. The strap in the points was touching the mounting screw for the points, under it. I got a flatter dead screw & filed a notch on the strap , and she fired right up.
The Following User Says Thank You to Esteban32696 For This Post:
Old 04-10-2019, 10:17:23 AM
Kevin K Kevin K is offline
Default Re: 1966 Onan CCK-MS/1196g Engine on a Miller Welder
You can download the engine manual here:
http://www.skilledcrafting.com/onanf...0(05-1982).pdf
Using a voltmeter, check for 12 volts at the positive terminal of the coil when the engine is cranking. If you have a 12 volt coil, you should have battery voltage at the coil positive terminal when cranking. If you have a 6 volt coil you will have a resistor in series with the positive coil terminal, and the voltage will be lower.
Connect the ground terminal of a test light to ground. Connect the other terminal of the test light to the negative terminal of the coil. When the engine is cranking the light should flash on and off.
Old 04-10-2019, 10:18:06 AM
Billy J Shafer's Avatar
You should also check the bolt. That goes through the point box. Where the wires hook up. Sometimes the insulator will crack letting the bolt ground out. Check the point rod make sure it is flat on the bottom. They can wear to one side which can change your point setting.
Old 04-18-2019, 12:18:17 PM
Okay so I just replaced my resistor. Still doing the same thing as before, I have 12 volts the entire way through the system, through the coil (primary winding) and up to the points box. Sometimes when I crank it I see a small arc where the points open, but no spark still.
Old 04-18-2019, 02:21:59 PM
I fixed it, replaced battery with another 12v and I had spark. Got it running great now. I think I may have been the batt all along, who knows. Thanks guys!!
Old 04-19-2019, 11:46:12 PM
cobbadog cobbadog is offline
Great result and well done.
Onan CCK-MS/1196G Serial no. 0869.43531 Welder Generator AngrySailor Onan Generators 7 01-20-2018 02:32:59 AM
ONAN CCK-MS / 1196G WELDER/GEN I need help Jhunsch Welding Shop 1 02-16-2017 05:33:45 PM
Onan MS/1196G Miller welder/generator starter part needed. 1outlaw Onan Generators 2 10-18-2015 10:13:04 PM
Miller Welder-Onan Engine Manual hoppyhunts Welding Shop 1 06-14-2010 01:27:26 PM
Miller welder with Onan Engine Replacing fuel pump with electric creedman Welding Shop 11 05-03-2010 02:01:19 PM
