Welding Shop
AC/DC Welding Questions
this thread has 138 replies and has been viewed 3755 times
Old 05-04-2019, 06:48:20 PM
Tracy T Tracy T is offline
Default Re: AC/DC welding questions
well the rain stopped and i headed to the shop, spring's are done! the last 3 photos show the spring in each of the three posistions as the brush wears to mantain correct pressure agaisnt the armature.
ID:	334121   Click image for larger version
ID:	334122   Click image for larger version
ID:	334123   Click image for larger version
The Following User Says Thank You to Tracy T For This Post:
Old 05-04-2019, 10:05:50 PM
my gosh! I need a better camera ASAP!!!! just look @ those Ronald McDonald clod hoppers peeking in there!
Old 05-04-2019, 10:55:30 PM
Vanman Vanman is offline
LOL! Yeah, I noticed those...
Old 05-05-2019, 01:10:29 AM
cobbadog cobbadog is offline
Never mind about ya boots in the shot. When I take a pic from that angle my atomic gut gets in the way.
Glad you are making progress. May not be the camera causing the blurry shot, it may well be camera shake when you press the button to take the pic or similar. To test this theory sit the camera on a solid surface and take a pic and see how it comes out.
Old 05-09-2019, 12:11:39 PM
got too many projects going on at the moment, currently 5, maybe 8! I have not quit though! if it turns into 8, 3 of those will take priority, those are paying gigs! 2 dozer work, and the other tractor work clearing land. two different roads to build with the dozer. I am going to knock out the smaller projects first or it going to snowball on me and i will never get caught up.
Old 05-12-2019, 07:28:13 PM
already snow balling! easy job, well not so easy! put a high bid in today on one of the paying gigs, we will see. waiting on parts for one job, waiting on response on the bid, looks like gonna be wet for a few days. so may be time to get back at welder! stay tuned.
  #47
Old 05-13-2019, 01:41:51 PM
well got the back ache today, so i decided to take on a sit down job on the welder. first coat of locktight liquid tape made its way onto the armature where the insulation is scuffed up. I think I am going to like this stuff, even smells like it is good stuff! its a little messy but it almost looks like the stuff a motor shop would use! its going to get several coats, got to wait a minium of 10 minutes btween coats. i will get some pictures up when its done, may be difficult though its dark in the shop and that armature weighs a ton so it wont get moved just to take some pictures.
  #48
Old 05-29-2019, 09:44:45 PM
well not much to report on the welder, but i had a little time today and so decided to do some work to the cart! got one wheel took apart cleaned up greased and back together. it aint new but does roll pretty nice! that inspired me to do another, got it apart and called it a day. I will take a few pics of it tomorrow. this welder needs to be mobile at least in the shop! I will have no need for the cart if all goes well, but i need the cart to function at the moment.
Old 05-30-2019, 01:18:10 AM
OnanParts's Avatar
OnanParts OnanParts is offline
Default Re: AC/DC Welding Questions
That's a late model welder! It was made around the time B-17's were extremely busy! 1943.
https://www.onanparts.com
The Following 3 Users Say Thank You to OnanParts For This Post:
  #50
Old 06-06-2019, 06:43:50 PM
starting to get caught up and hoping to get back to my welder! question for you guys, how to clean up the steel in the stator? wire brush, sandpaper, scotchbrite on my die grinder? with some small touch ups the amarture can go back in! and will free up some much needed shop space! i know i have been deadbeating around on it but for many good reasons, first and foremost to give it time to air out and dry!
Old 06-09-2019, 04:40:16 PM
things are starting to look up! its a tripod as of now but does roll quite easy, the center is broken out of one front wheel. no big deal just needs welded back in. so i had a little time today and took the control section apart, can you say OVERBUILT!! nothing in there hurt either! just a little cleaning was all that was needed. the fine tuning works measured from my cheepo meter it ranges from .05 ohms up 67 ohms. I have not checked out the apmrage adjustment yet because it is apart for cleaning. while i have it out i am going to run new wiring to everything in the control box. Its tight as hell in there with the amp adjust in place. I need to get after it before i forget where everything goes, I had that moment today and am going to make a note of it in this thread. 5 wires coming out of controll box, 3 go to the exciter and the other two in the generator. scotchbrite rolock disc cleaned the steel up perfectly. thinking what to use to prevent rust, paint, clear? we used clear in a spray can on transformers on parts that couldnt be dipped. pictures to come, I know how you all like pictures! vanman if you are still following i may have some questions on motoring this thing up with batteries.
  #52
Old 06-09-2019, 07:45:52 PM
Yep, still here! Just appreciating your perserverence!
Keith
  #53
Old 06-09-2019, 10:07:04 PM
dkamp dkamp is offline
eMail NOT Working
Great thread, Tracy... but needs more PICTURES!
3M makes an insulating spray 1602 R, I believe that's the same stuff we used to use for insulating flyback circuits on Cathode Ray Tubes (TV sets)... I'd use that on the wiring, and perhaps even a thin coat on the polepiece/laminate areas you're concerned about...
  #54
Old 06-22-2019, 01:39:09 PM
ya i know! this is looking like it is going to turn into a winter project. wifes car failed state inspection, bad tire and wheelbearing, no problem. when i start to replace the wheelbearing the front brake pads are shot! damn inspector didnt even check that. replace brakes and wheel bearing send her back to get a tire and that inspector is not there that day so another goes to checking, another bad wheel bearing, and inner tie rod! that SHOULD have been wrote up the first go around. brakes stuck on my track loader, get that fixed and now the head gasket is pouring. and customers are coming out of the wood work, where is that one legged man in a butt kicking contest emogie? thats me here latley!
Old 06-22-2019, 02:08:55 PM
here are a few of the control box.
ID:	337677   Click image for larger version
ID:	337678   Click image for larger version
ID:	337679   Click image for larger version
  #56
Old 06-22-2019, 02:26:03 PM
hear are a few shots of the control on the left in the first picture, i have the ohm meter hooked up i dont know if it will show up in the pictures but it is very sensetive!
ID:	337685   Click image for larger version
ID:	337686   Click image for larger version
ID:	337687   Click image for larger version
Old 06-22-2019, 02:35:26 PM
and of the control on the right. this some beach is HEAVY!
ID:	337689   Click image for larger version
Old 06-22-2019, 02:39:57 PM
Virginia car inspections. Another state to scratch off the list in our hunt for a place to live. Crashes are so rarely actually caused be mechanical failure that you can basically say that crashes are not caused by mechanical failure. Just another state money and control grab.
I believe the last photo in the first set is the welding polarity switch?
The last photos looks like a big choke/reactor? Does it have taps? Or a wiper? Looks like winding size varies from one end to the other.
Keith
Old 06-22-2019, 02:40:33 PM
here are a few of the steel cleaned up, hopefully they will turn out. one with flash and one without.
ID:	337693   Click image for larger version
  #60
Old 06-22-2019, 02:51:55 PM
last wheel to work on, 17 rollers in each wheel IIRC, center has broken the weld loose on this one. I may start on this one after this post, might even old skool it with the oxy/ acy torches and a brass rod or coat hanger. just cause i can! sorry i put you guys into DT's with the pictures.
ID:	337695   Click image for larger version
ID:	337696   Click image for larger version
ID:	337697   Click image for larger version
Farmll Regular Cracked Block Questions on Welding Gasengin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 18 12-27-2016 11:49:34 AM
AC or AC/DC for Welding Shay 5 fan Welding Shop 8 01-18-2012 02:23:13 PM
Welding rod Chris J Welding Shop 7 08-17-2008 10:22:53 AM
Thoughts on crankshaft welding/ engine block welding Mac Leod Small Air Cooled Gasoline Engines 10 04-14-2008 10:46:02 PM
Questions on welding cast iron Neill Hit & Miss Gas Engine Discussion 4 10-08-2007 05:25:27 PM
