Welding Shop
Flat Twin Welding Generator Family Tree
this thread has 4 replies and has been viewed 517 times
Old 05-11-2019, 03:09:58 PM
rprohask rprohask is offline
Default Flat Twin Welding Generator Family Tree
There were once quite a few flat-twin-engine welding generators, not
to mention electric light plants, that are outwardly very similar. Does
anybody know to what extent they share a common ancestor, and what
that ancestor might be?
The most obvious examples are Miller Legend and Lincoln Ranger, but
a few other brands surface from time to time; Hobart, Airco and probably
others. Onan and Kohler both made lighting plants in the same pattern.
Any insights appreciated, thanks for reading!
bob prohaska
Old 05-11-2019, 06:57:43 PM
Default Re: flat twin welding generator family tree
My Miller AEAD and Airco Wasp are basically the same set but @ 20yrs between them. The Wasp is rope start and mag fired with knife switche to change from power to weld and constant speed. The Miller is battery start, auto idle, toggle switch selectable power. Both good little machines.
Old 05-13-2019, 01:00:39 PM
m_thompson m_thompson is offline
I have a P&H DC welder / AC generator powered by an Onan CCK twin. I have seen the same welder sold under different names with just small differences in the design.
Old 05-13-2019, 03:44:59 PM
Any hint who made the welders? Clear enough that Onan built
the engines, but what about the generator heads? Frames? Controls?
Thanks for replying!
bob prohaska
Old 05-24-2019, 11:31:02 AM
OnanParts's Avatar
OnanParts OnanParts is offline
Default Re: Flat Twin Welding Generator Family Tree
Onan was the most popular flat twin used by Miller, Lincoln and Hobart. Many of the rebranded Onan powered welders were made by Miller. Onan also made welder/generators under their own name too.
Kohler flat twins were found on Hobart welders for awhile. B&S flat twins also used by Lincoln.
A quick look in the archives I came up with some Onan production orders/build sheets for Miller from 1956, Hobart from 1957 and the oldest Lincoln so far from 1966.
ID:	335466   Click image for larger version
ID:	335467   Click image for larger version
https://www.onanparts.com
WW1 ABC 500CC Flat Twin skankingiant Small Air Cooled Gasoline Engines 21 10-11-2015 04:19:13 AM
Lawrance flat twin zdgenset32 Multi-Cylinder Stationary Gasoline Engines and Power Units 1 10-06-2014 09:09:07 AM
Christmas tree fun with the family & Unstyled L jaw123 Antique Farm Tractors 1 12-20-2012 09:59:11 PM
Family Tree - Steam Traction Engine guyvapeur Steam Stationary Engines, Traction Engines 5 03-25-2007 08:20:11 AM
