Welding Shop
Airco Wasp model 2.25A/DDG-AMEL-A
this thread has 2 replies and has been viewed 312 times
Closed Thread
Old 07-06-2019, 08:31:26 AM
Sbouvia Sbouvia is offline
Default Airco Wasp model 2.25A/DDG-AMEL-A
Hello long time lurker first time poster. I have an older Airco Wasp model 2.25A/DDG-AMEL-A serial number T436731 welder/generator and am trying to find any and all information action to get it back running. It has an Onan CCK-MS/1196G with the serial number 127CA08117. I wasnít sure if I should post about the Onan in the Onan generator forum or here. If I have generator specific questions should I post here or there? Iíve just started taking apart the generator as I have no idea the last time it ran. So far I have tore apart and cleaned the carb and have started looking into the ignition system for the generator. It is a battery start model so it has a starter relay, ignition switch and start button. It looks to have the 6 volt coil and I will post about that later.
Old 07-06-2019, 02:44:37 PM
Default Re: Airco Wasp model 2.25A/DDG-AMEL-A
I also have an older Wasp in the barn, its a project for another day. Really nice little compact machine. I would say this is a good place to find info on the little Wasp. its actually a generator that also welds.
Your machine was the same as some of the early Miller machines. go to the miller website and look up info on the Legend series or AEA machines IIRC.
A lot of people here with way more knowledge than I. they can answer most any question you have.
Old 07-19-2019, 11:07:53 AM
Harry's Avatar
This thread moved to the Onan Generator forum...
https://www.smokstak.com/forum/showthread.php?t=188018
(See our Terms of Service)
Closed Thread
Clinton D35 Wasp Kammer0072000 Chain Saw Collectors 1 06-18-2017 08:51:48 PM
Airco Wasp II Horse Power at 511 Welding Shop 1 01-08-2012 05:25:08 PM
1/5 Scale 18 Cylinder R-2800 Double Wasp John Davis YouTube Old Iron Videos 2 12-04-2011 10:52:58 AM
Airco Wasp 225/200 AC/DC Welder Problems LCJudge Welding Shop 1 07-10-2009 12:51:10 PM
