Welding Shop
Miller SRH-333/Hanovia 3 Phase to Single Phase Conversion
this thread has 64 replies and has been viewed 7534 times
Old 08-12-2019, 12:03:32 AM
dkamp dkamp is offline
eMail NOT Working
Default Re: Miller SRH-333/Hanovia 3 Phase to Single Phase Conversion
Well, with those capacitors installed, when you go to strike an arc with welding leads, make sure you're extremely well protected. The instantanious current of those capacitors discharging will probably turn your welding rod into a fuse... that's a serious can of electrons you'll have bottled up there.
Keep in mind that a constant-current welding power supply has two functions: First is to provide a proper voltage for a managable arc... and the other is to provide a stable current that varies only slightly with arc. The inductance of the windings makes a welder self-limiting, either as a constant-current, or constant voltage supply. Adding a buttload of capacitance turns it into a very... well... it'll bite really hard.
Old 08-13-2019, 12:36:12 AM
Your concerns have been noted and recorded! I looked at all versions of SRH333 on Millers site today, and none show the exact circuit diagram for my machine, main difference being the lack of Z2 (transformer) which my unit has. I did find mention (in SRH333 manual) of an optional "start control" for easy arc starting on thin materials, only available for Gold Star 333 and 444, yet no description of what is involved in the circuitry. In looking at manuals I see no Gold Star 333 or 444.
In looking at the SRH manuals, all versions have the .05uf caps, only some versions have the .5uf caps. In camparing your schematic to my schematic, I think your .5uf capacitor is in a different part of the circuit, or at least its drawn that way, as best I can tell.
Without definitive info, I don't know what else to do than try it
If I'm still around I'll give an update tomorrow.
Old 08-14-2019, 07:56:16 PM
Well I didn't dieded. Just finished initial testing and it seems to weld great, nice easy arc start, nice quiet arc. Initial testing was done using some old stock, long open can, 7018 rods, 1/8" electrode, reverse polarity (electrode positive). seemed to weld best between 75% to 100% on amperage control knob, low negative, have not tried high negative yet. No idea what meters are reading, or if they even work, leads are 50' long and I'm welding outside. Did stick the rod a couple times, something on machine did not like that, maybe contactors chattering?
Caveat: As for my description of how its working, I have not stick welded in 30 or so years, so not a lot to compare to
  #64
Old 08-14-2019, 08:39:04 PM
After 99 months and 30 days, you have a functional welding machine. That is faster results than some of my projects.
  #65
Old 08-24-2019, 11:23:07 PM
eMail NOT Working
I resemble that remark, too...
15.0 JC-4XR 277/480 three-phase conversion to 120/240 single-phase? Chaz H Onan Generators 20 10-08-2018 04:52:42 PM
Another stupid question about converting from single phase 120v to single phase 240v! Patrick Onan Generators 7 11-30-2011 02:08:16 PM
3 Phase to Single Phase Conversion Jim McIntyre Generators & Electric Motors General Discussion 10 04-03-2011 06:58:39 AM
US Motor Div Generator Conversion To Single Phase 220V From Three Phase jimybud Generators & Electric Motors General Discussion 4 06-27-2010 08:19:50 PM
3-Phase to Single phase Conversion Dewey Kohler Generators 5 10-06-2005 05:54:30 PM
