Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
D8 Caterpillar Dozer, 2U Series
this thread has 23 replies and has been viewed 17584 times
Old 05-29-2016, 08:06:36 AM
Tracy T Tracy T is offline
Default Re: D8 Caterpillar Dozer, 2U series
Sorry to dig up a old thread but this is the closest I have found to what we are working on, owner said his was a 1h, it looks almost identical to the one pictured in the beginning of this thread with the exception of the cable lift. His cable is overhead. Does anybody know how much lube the transmission & final drives hold? It has the dry clutch if that helps. This unit has been broke down for at least 11 years, so I asked him about it. Turns out lack of interest. We made a deal I helped him get it started track back on and blade put back on for the use of it if I supply the needed lube. Not a bad deal if you ask me considering it only took about half a day to get to this point!
Old 05-29-2016, 10:04:54 AM
BHoward BHoward is offline
I had 2 Gardner Denver compresers that had the D 8 engines when I was in the sand blasting business .
Old 05-29-2016, 12:47:17 PM
from what i can come up with it looks like the transmission holds 41 qts & the final drives hold 20 qts each, sound close?
Old 06-23-2016, 07:46:10 AM
Update the final drives do hold right at 5 gallons each, as for the transmission it was running out the hole where you check it at about 7 gallons. Both were completely dry because the owner had drained them for repairs. I sure am glad it didn't hold 50 gallons like he thought!
The Following User Says Thank You to Tracy T For This Post:
Cummins A Series (Onan L Series) L423D fuel pump problem? ichudov Onan Generators 23 09-22-2015 08:36:44 PM
Caterpillar D4 Dozer Value M&WJOE Dozers and Crawlers 3 06-19-2014 09:50:34 AM
D2 Caterpillar dozer Caterpillarcrazy Dozers and Crawlers 9 01-26-2010 10:45:57 AM
JB Series and JC Series service manuals Cat Man Onan Generators 6 12-27-2008 12:06:06 AM
Cletrac PTOs: is a A series compatable with E series? Rene Elliott Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 06-10-2008 12:05:37 AM
