Oil Field Engines
Go Back   SmokStak > SmokStak® Antique Engine Community > Oil Field Engines
Oil Field Engines A gathering place for OFES members otherwise known as "Oafs". Basically, if you like "BIG OLD GREASY RUSTY OIL FIELD ENGINES, you're in the right place. Founded by Russell Farmer.
Oil Field Engines
No check valves in Powell-Boson oiler?
this thread has 10 replies and has been viewed 2252 times
Old 02-13-2018, 04:19:46 PM
Exclamation Re: No check valves in Powell-Boson oiler?
On the OC/SP engines, the oiler is mounted on the transfer port cover. Some oil drips right on the piston, some right on the rings, and some falls thru into the cylinder. All depends where the piston is when the drop falls!
Powell Oiler Greg Mosley Oil Field Engines 4 08-08-2016 10:26:13 PM
Powell Oiler Bryant Antique Gas Engine Discussion 4 04-05-2016 09:45:54 PM
powell-boson oiler knobs con-rad Oil Field Engines 7 02-02-2014 03:03:02 PM
Powell s oiler Brian.P Antique Gas Engine Discussion 0 12-16-2012 05:13:22 PM
POWELL'S 1PT. OILER TOM Antique Engine Archives 0 06-04-2001 08:21:47 PM
