Oil Field Engines
Ajax 6 1/2 x 8 Weight?
this thread has 7 replies and has been viewed 941 times
Old 12-17-2017, 06:05:25 AM
lanterncollector lanterncollector is offline
Exclamation Ajax 6 1/2 x 8 Weight?
may be a new owner of an Ajax 6 1/2 x 8 in the near future... just wondered if anyone knew the approx. weight? need to know whether my single axle trailer will be enough or if ill need to dig out the tandem axle!
thanks
Old 12-17-2017, 09:34:49 AM
KeithW's Avatar
KeithW KeithW is offline
Default Re: Ajax 6 1/2 x 8 weight?
I am sure someone will post the exact weight but 3000-4000 pounds. My 7 1/2 X 10 including trailer weighs 7,000 lbs.
The Following User Says Thank You to KeithW For This Post:
Old 12-17-2017, 12:53:54 PM
thanks.
Old 12-17-2017, 07:03:22 PM
** Just found on a rebuilder's site that they weigh 2900 lbs. not sure if we or dry weight, but i'm posting it here to help others who may need it.
Old 12-19-2017, 04:46:48 PM
Default Re: Ajax 6 1/2 x 8 Weight?
Might be a bit much for a single axle, especially if you intend to run it on the trailer!
Old 12-19-2017, 07:18:19 PM
yea i was just picking it up with it. ill have to find another for it to be mounted on. its too heavy for the single. gonna have to dig out the tandem.
Old 02-24-2018, 03:43:40 PM
Get it home yet?
Old 02-24-2018, 09:39:03 PM
Get it home yet?
actually found a 7 1/4x 8 that im picking up once the ground dries up. with the rain & snow we got here it probably wont be till april now
Ajax E42 Marshall Henderson Oil Field Engines & Related Equipment 5 02-13-2016 11:01:50 AM
115 H.P. Ajax Fred Van Hook YouTube Old Iron Videos 1 05-01-2012 07:55:10 PM
Ajax 11&1/2 X 12 help! Firewoodguy Steam Stationary Engines, Traction Engines, Steam Boats 1 03-16-2010 08:01:26 AM
New Ajax 5 X 6 1/2 Chuck Ostrander Oil Field Engines & Related Equipment 5 11-06-2009 11:52:23 AM
12 X15 Cm Ajax Bill Geyer Oil Field Engines & Related Equipment 69 05-22-2009 09:56:39 PM
