Oil Field Engines
Go Back   SmokStak > SmokStak® Antique Engine Community > Oil Field Engines
Oil Field Engines A gathering place for OFES members otherwise known as "Oafs". Basically, if you like "BIG OLD GREASY RUSTY OIL FIELD ENGINES, you're in the right place. Founded by Russell Farmer.
Oil Field Engines
not an engine - The Refinery Supply Co. Device
this thread has 5 replies and has been viewed 1234 times
Old 12-22-2017, 01:49:38 PM
matt0025 matt0025 is offline
Default not an engine - The Refinery Supply Co. Device
I'm hoping someone here can help with this device. It was in dad's attic and he doesn't remember anything about it....he's at that stage.
The only two things I found were the patent and an old chemistry journal advertisement. I have not found any other instances looking through Oil and gas Museum pictures online. The patent said it was "...adapted for use in determining the specific gravity of gases."
I'm trying to get some info so I can decide to clean it up it or pass it on to someone with an interest in this. It's to handle pressure or vacuum. There's a glass tube that looks like a filter of sorts, but don't know if it's incoming or outgoing.
I'll get some better pictures later today.
Any help is appreciated.
Matt
ID:	298786   Click image for larger version
The Following User Says Thank You to matt0025 For This Post:
Old 12-23-2017, 11:58:39 AM
51cub 51cub is offline
Default Re: not an engine - The Refinery Supply Co. Device
I might not be any help, except maybe give you more places to ask around. It reminds me of the thing heating guys use to measure the draft of a furnace when they service it. I don't know of any forums like that to go to, but if you know somebody in the business, you can ask them
Old 12-23-2017, 12:48:17 PM
Thanks. I'll check around on that path.
Old 12-23-2017, 01:01:30 PM
Here's a few more pics. There's a nut driver next to the fittings. It matches the size needed to open the access cover.
I rather not open it until I find out more about it. There may be a clean chamber or something since it is supposed to measure gases. There's a filter or dryer on the base with a petcock. I figure it's to relieve pressure...+ or -...since the petcock goes to atmosphere without any kind of connection.
ID:	298846   Click image for larger version
ID:	298847   Click image for larger version
ID:	298848   Click image for larger version
Old 02-23-2018, 09:42:25 PM
dkamp dkamp is offline
eMail NOT Working
I'll throw this one out for a guess...
Brass-era automotive carbide/water acetylene generator?
Old 02-23-2018, 11:48:13 PM
Jake Jacobs Jake Jacobs is offline
https://nvlpubs.nist.gov/nistpubs/nb...icpaperT89.pdf Look at page 7 and 10.
---------- Post added at 09:29:05 PM ---------- Previous post was at 09:24:05 PM ----------
Try page 9, not 10
---------- Post added at 09:32:57 PM ---------- Previous post was at 09:29:05 PM ----------
May have been used to find the specific gravity( density) of gas from an oil well or gas well. This would tell you the type of gas you have. Looks like a balance scale on the one end.
---------- Post added at 09:48:13 PM ---------- Previous post was at 09:32:57 PM ----------
Here is one for sale on ebay. Look at the end with the scale. Same name as yours. This is it!!!!!!!!!!!!!!!! https://www.ebay.com/itm/Vintage-ACM...19.m1438.l2649
The Following User Says Thank You to Jake Jacobs For This Post:
Steam Engine Testing Device Jack Innes eBayŠ Auction Discussion 0 01-06-2017 09:28:18 AM
New player in town supply side - Amazon Supply! PTSideshow Machine Shop and Tool Talk 1 04-25-2012 02:59:59 PM
Device on MM Universal engine ??? E27N Antique Farm Tractors 4 03-18-2011 11:20:50 AM
Small Engine Break-in Device dkirk Small Air Cooled Gasoline Engines 11 02-15-2011 01:11:11 AM
