Oil Field Engines
3 hp IH Engine Info
this thread has 3 replies and has been viewed 904 times
Old 02-07-2018, 03:02:04 PM
Reed Engine's Avatar
Default 3 hp IH Engine Info
Looks like I’m going to be working on the cylinder and or the piston. What is the stock bore? If anyone can tell me?
Old 02-08-2018, 11:34:26 AM
Joel Mosley's Avatar
Joel Mosley Joel Mosley is offline
Images: 26
Default Re: 3 hp IH Engine Info
Hello Reed Engine. You might want to repost this in the main smokstak board, "Antique Engine Discussion". Also, is this a 3 HP M or a 3 HP Vertical Famous??
Good luck.
The Following User Says Thank You to Joel Mosley For This Post:
Old 02-10-2018, 04:13:16 PM
I believe the bore on the 3 HP M is 4"
Old 02-10-2018, 08:12:43 PM
]Thank you. I haven't seen it yet but understand the piston is 4.125 ish. That sounded like an oversize to me if I were guessing. Not sure if I'll bore the cylinder true and sleeve the piston or bore and sleeve the cylinder to std and then turn the piston down.
I post some pics when if arrives. I'll definitely make sure the owner is on board no matter how the fix goes.
Unknown Engine. please help info needed! Scooter engine? MedicHamilton Small Air Cooled Gasoline Engines 5 04-04-2011 05:32:53 PM
Fire eater engine/vacuum engine info Luke Struik Scale Model Engineering 4 04-13-2009 02:41:09 PM
engine id/info Nick Antique Gas Engine Discussion 3 08-01-2005 07:20:12 PM
Mar-tan Engine Info Jeff Schoch Antique Engine Archives 2 10-25-2004 02:06:29 AM
Engine Info. Bob Willemsen Antique Engine Archives 1 11-21-2003 11:36:07 AM
