Oil Field Engines
15 hp Olin Parts Needed
this thread has 5 replies and has been viewed 800 times
Old 03-05-2018, 04:18:55 PM
5hpGalloway 5hpGalloway is offline
Default 15 hp Olin Parts Needed
Hello all i am working on a 15 hp olin right now and I am trying to find the eccentric parts for a OC wico magneto and mount any help would be great thank you in advance
Old 03-05-2018, 06:11:51 PM
Russell Walker Russell Walker is offline
Default Re: 15 hp Olin Parts Needed
Is your engine 2 cylcle ? Do you have a cam gear I guess I want to ask. I have a OC on a 15 FBM Z that don't belong there but looks like it dose belong operated by cam gear. can try picx. if it would help. Russ
The Following User Says Thank You to Russell Walker For This Post:
Old 03-05-2018, 08:22:51 PM
My engine is hit and miss. I believe they had them mounted both ways one being by eccentric at an angle mounted to the base and two bing straight up and down mounted right over the cam gear I would take ether the eccentric or above cam gear style magneto set up as long as it works with a OC wico which is what I have . I have also seen wico R1 magnetos on them not sure if they will interchange? ?
Thanks,Ethan
---------- Post added at 08:22:51 PM ---------- Previous post was at 08:20:23 PM ----------
Any pictures would be great! !!
Thank, Ethan
Old 03-06-2018, 09:07:54 AM
Just ideas if I can get the pics here. Russ
ID:	304779   Click image for larger version
ID:	304780   Click image for larger version
Old 03-07-2018, 03:36:27 PM
I would love to set my engine up in that way but I would need all the working parts for the backside of the mag all I have is the Magneto it self Any armatures or anything that goes with that mag would be great!!!
Old 03-07-2018, 06:46:01 PM
Sorry cannot help you there. I was just throwing out the idea sorry Russ
Parts for a 25 hp Olin GW Eddy Oil Field Engines & Related Equipment 0 08-28-2016 09:28:34 PM
Olin video Woody Sins Antique Gas Engine Discussion 0 07-15-2013 08:48:27 PM
4 H.P. Olin Fred Van Hook Antique Gas Engine Discussion 0 03-05-2013 04:47:23 PM
Olin HP? CStaples Oil Field Engines & Related Equipment 11 02-19-2012 05:39:47 PM
help needed B&S parts list needed desotonut1953 Small Air Cooled Gasoline Engines 0 08-31-2010 12:07:38 AM
