Oil Field Engines
Go Back   SmokStak > SmokStak® Antique Engine Community > Oil Field Engines
Oil Field Engines A gathering place for OFES members otherwise known as "Oafs". Basically, if you like "BIG OLD GREASY RUSTY OIL FIELD ENGINES, you're in the right place. Founded by Russell Farmer.
Oil Field Engines
Ajax DP 160 Specifications?
this thread has 6 replies and has been viewed 499 times
Old 03-12-2018, 10:17:36 AM
critt77matt critt77matt is offline
Default Ajax DP 160 Specifications?
I have found what I believe to be an Ajax DP 160.
anybody have the specifications on this engine? Weight?
Curious to the value of these engines. Was supposedly rebuilt 10 years ago but never ran. Looks like it does NOT have a clutch but does have a pulley for a cog belt. It was possibly coupled to a compressor at one time.
Old 03-13-2018, 01:30:20 AM
Compressorman Pat Compressorman Pat is offline
Default Re: Ajax DP 160 Specifications?
DP 160, twin cylinder. 11" bore, 14" stroke. I have Ajax manuals and books but they do not mention weight. As for the value, It might be worth something to the right guy. However, they don't pass many clean air requirements and have become boat anchors
Old 03-13-2018, 04:05:11 PM
Reed Engine's Avatar
You might try calling Osborn in NM. 505-327-4113
Old 03-13-2018, 04:59:33 PM
If you find out what it weighs, let us know! Is it a 2 or 4 stroke engine?
Old 03-14-2018, 09:14:15 AM
Allan Wright Allan Wright is offline
All Ajax engines that I have seen are two stroke. I’m not aware of any four stroke.
Old 03-14-2018, 09:49:30 AM
KeithW's Avatar
KeithW KeithW is offline
It should be over 10,000 pounds as my 7 1/2 x 10 single is about 5k.
Old 03-14-2018, 11:17:52 AM
I assumed it was a 2 stroke, since all the ones I have seen are 2 stoke natural or well head gas.
If it is under 20,000lb I can haul it on my duel tandem but loading it might be a different story.
Big oil field engines don't seem to be worth much.
Briggs 210415 Specifications gvasale Small Air Cooled Gasoline Engines 8 01-02-2018 10:27:13 AM
Dempster Gas Tank Specifications Larry K Antique Gas Engine Discussion 2 01-10-2014 12:52:11 AM
Injector specifications Bob Upham Steam Stationary Engines, Traction Engines, Steam Boats 5 09-08-2010 03:32:07 PM
Torque specifications gruby26 Small Air Cooled Gasoline Engines 6 01-17-2009 12:35:09 PM
Hercules piston specifications Mike D1 Antique Gas Engine Discussion 0 08-29-2005 09:04:08 AM
