15.0JC Need Head Gaskets
this thread has 1 replies and has been viewed 2129 times
Old 06-10-2007, 01:43:28 PM
pcbye
Default 15.0JC Need Head Gaskets
Greetings:
Does anyone know where I might obtain a set of head gaskets for a 15.0JC.
I am going to pull the heads and clean the combustion chambers and possibly have a valve job done.
I have the unit all tuned up, electronic ignition, new plugs, cap, rotor, wires, etc. and the timing set to 35 BTC on propane. It is a Spec S setup for gas -- 15.OJC-3CR/8505S. So I assume it does not have 9:1 compression, that should be Spec U & W sets for Natural Gas Only.
It runs real well, although It seems to run hot and will start to knock a little after running for about 45 minutes under about 1/2 - 3/4 load.
The head temps also seem a little high at around 375 F, and number 2 around 410 F. I am thinking that it had been running so badly at the time it was removed that it is most likely carboned up -- compression is good, but also a bit too high. 230 Psi Cold Cranking.
The service manual indicates that you put Permatex #3 on both sides of the gasket? Sounds archaic.
Is there any thing I should look for once the top is off?
Best regards;
Peter
Old 06-10-2007, 05:06:30 PM
Joe Stewart Joe Stewart is offline
Default Re: 15.0JC Need Head Gaskets
I just bought a pair of head gaskets for my JC. I got them at the local Onan/Cummins dealer. Cost was $17.82 apiece plus $5.20 for the UPS charge to send them to my house (the dealer was about 20 miles away, so I had them shipped rather than driving there). J. Stewart
Head Gaskets Byron Roberts Antique Gas Engine Discussion 6 03-11-2005 07:36:46 AM
Reusing Head Gaskets Larry Kastens Antique Engine Archives 11 08-02-2004 11:14:07 PM
head gaskets smootz Antique Engine Archives 16 11-13-2002 08:43:44 AM
Ignitor and Head Gaskets Dave U Antique Engine Archives 8 02-11-2002 09:32:40 PM
Head Gaskets Tom Jamboretz Antique Engine Archives 6 12-01-2001 10:21:43 PM
