Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Generac Generators (SEARS, etc.)
Generac Generators (SEARS, etc.) Restoring, maintaining and operating Generac generators.
Generac Voltage Regulator Reverse Engineered...
this thread has 51 replies and has been viewed 78747 times
Old 05-04-2017, 09:41:16 AM
ROMOAS ROMOAS is offline
Default Re: Generac Voltage Regulator Reverse Engineered...
Originally Posted by jimgrease View Post
First post here at smokstak. I found this forum while doing research on my new to me but very old JC Penny 5000 watt generator. It's made by Generac and has a 10 HP Briggs side valve engine.
The voltage regulator board is identical to the MC-40 PCB posted here. There is only one part difference that I can tell, my board has an extra MOV.
Anyway, my generator runs but the voltage output was low. The 120 was at 36 volts, with the 220 at 72 V.
So I started the tear down and inspection process last weekend and finally got around to removing the potting from my PCB. Whew, what a mess
I'm about finished with the schematic drawings and I also know that at least one part on my PCB is fried. It happens to be the extra MOV, and it's shorted out depriving the Op-Amp IC of power.
If anyone is interested in my work, please reply and let me know that there is still interest in this old voltage regulator. I can post schematics and continue the discussion on this circuit.
I was looking around to see if anything newer could be easily built, but there are no complete schematics of a better circuit that I could find on the internet. If you know of any, please post a link. I'd like to compare this old op amp circuit to more modern designs.
Here is a photo of this old 1978 JC Penny generator:
what did you use for removing the potting
Old 05-04-2017, 10:53:36 PM
If you follow one of the links in previous posts he states he used a heat gun and screwdriver.
Doc
This mind left intentionally blank
Generac 20kw Propane Regulator JBittnerSr Generac Generators (SEARS, etc.) 5 03-31-2011 01:32:28 PM
Voltage Regulator for MC-40 Generac golddredger Generac Generators (SEARS, etc.) 10 01-21-2011 12:50:10 AM
Generac 5.5 (RV) voltage surges jerseyjim Generac Generators (SEARS, etc.) 4 08-28-2009 01:29:17 AM
Generac voltage problems kphee Generac Generators (SEARS, etc.) 6 12-09-2008 12:57:51 AM
Generac regulator Andre Blanchard Generac Generators (SEARS, etc.) 2 02-06-2006 12:34:11 PM
