Smokstak Down Under
Southern Cross MKJ
this thread has 11 replies and has been viewed 1097 times
Old 10-16-2017, 11:57:42 AM
gcm gcm is offline
Default Southern Cross MKJ
I am in process of restoring a 1949 Farm Pumper. I am missing a magneto and nowhere can I find the Type & Model on the web.
I have now decided to modify another magneto for the time being, but to do that I need to cut a new gear to fit on the Pumper crank.
I saw some guys mention a 16teeth but the gear on my crank is only a 14 teeth. Does anybody maybe know the exact sizes for the gear because I would like to import the correct involute gear cutters to cut a new gear. Here in South Africa is only metric cutters freely available. Sorry I am lazy and should sit and calculate it but I am sure it is faster to ask and hopefully not necessary to reinvent the wheel.
Old 10-16-2017, 05:49:55 PM
Scotty 2 Scotty 2 is offline
Default Re: Southern Cross mkj
Hello all
Crikey. The J I'm playing with at the moment has 26 teeth on the crankshaft for the magneto drive and 24 teeth for the timing gears.
Cheers Scott
Old 10-16-2017, 05:53:25 PM
Famous Fitter Famous Fitter is offline
HI gcm,
Good to hear you are restoring a good old Pumper. I'm guessing that it should have a Lucas Magneto. Pretty sure The Gear is 26 teeth and there is a brass sealing plate that sits between the gear and magneto with a felt seal in it. the gear has a small boss on it for the seal.
I can work out what DP the gear is and the dimensions to make one, I have one (Southern cross gear) somewhere up in the mess i call a shed, I have a few Farm Pumpers of Various makes and lots of bits and pieces.
I'll ask around in case someone has the parts laying around
I live only 150KM from Toowoomba where your engine is made !!!!
Cheers Justin.
P.S. There is an excellent book on the history of Southern Cross Products called "Southern Cross Engines". A search should find it online.
The Following 2 Users Say Thank You to Famous Fitter For This Post:
Old 10-17-2017, 01:58:52 AM
cobbadog cobbadog is offline
Maybe by sending a PM to Rob.S here on this Forum as he just might have a gear ready to dispatch. Last time I was on his property he had a 5 acre paddock of cast iron growing everywhere.
Old 10-17-2017, 03:42:09 AM
gcm gcm is offline
Thank you for the replies. I must apologize, I have counted the teeth on the wrong gear Counted the teeth when the crank was outside on the table.
It is indeed a 26 teeth. What confuse me now is that "Scotty 2" says the magneto is a 24teeth and I would have thought it should be a 1:1 ratio to spark at the correct position.
So much to learn ;-) which makes me think - maybe I should search harder to find the correct magneto. Less frustration in the long run and also nicer to have the real thing for a restoration.
Old 10-17-2017, 05:52:20 PM
Default Re: Southern Cross MKJ
Hello all
I received some information that may be of interest yesterday.
I did not know this but there were some Southern Cross engines made in South Africa.
I think you may have misread my post GC. Both Justin and I said the number of teeth on the gear on the crank to drive the magneto is 26 teeth. There are 24 teeth on the gear on the crank to drive the timing gear not the magneto.
What is the serial number of your J GC? It may help to identify if your pumper is Australian made or South African made.
I was also sent this list. A list of magneto's that were used on Southern Cross engines.
Cheers Scott
Old 10-17-2017, 07:23:46 PM
Winchester Winchester is offline
Yes well when Uncle Herb ,whom I have mentioned in posts previously ,bought his SC Pumper in 1940 it was fitted with the magneto as shown.It is a 26 tooth pinion
Old 10-17-2017, 07:28:03 PM
Sorry for that error ...................Uncle Herb's magneto.
Old 10-18-2017, 01:13:31 AM
This is the Lucas Maggy on our Buzacott Farm Pumper. I get them back to front, it is either a RS1 or a SR1 but lean towards the RS1.
Old 10-18-2017, 03:02:28 AM
gcm gcm is offline
Good Morning,
Again thank you very much for the feedback and I apologize for the misunderstanding. I am quite new in this "hobby" and have lots and lots to learn.
Her serial number is 34864 and my guess is somewhere in 1949.
Attached is a pic what she looked like when she came to me, missing the magneto, oiler broken off (missing) and some spares in a plastic bag. My theory is that the magneto broke and was removed but never repaired. The white metal bearings and gears show very limited wear. It looks as if she must have fallen over at some stage because the carb has broken off in the head. The piston was stuck but after 2 weeks in the molasses all rust was removed and piston removed. Even the piston rings have enough spring in them to have another go at live.
Second pic is my work in progress. I tried to get the color mixed correctly but it was quite an exercise to explain to the guy what the old Australian Railway Cart's color looked like
ID:	293901   Click image for larger version
The Following 2 Users Say Thank You to gcm For This Post:
Old 10-18-2017, 05:59:51 PM
Hello GC.
No need to apologise matey. I'm still learning so much, after only been in the hobby a couple of years, it's not funny. Most people are just wanting to help and I thank them for it..
It looks as though your engine is in great shape. A big help if things are on good condition.
It does appear your engine is an Australian made on as it's bang in the middle of known engines in the registry. I believe Southern Cross made engines in batches and your engines appears to be in one of those batches.
We're working on a 1953 model of the J and I can see some differences to yours. We have a different crankcase for starters.
Cheers Scott
Old 10-18-2017, 06:20:04 PM
The 2 common "REDS" used in Australia were Post Office Red and Dog D**k Red
Southern Cross AKB 3 JeffR Smokstak Down Under 39 03-29-2017 09:03:37 AM
Southern Cross Rob.S Smokstak Down Under 6 06-30-2015 07:02:34 PM
Southern Cross Rusty Engines Smokstak Down Under 0 04-21-2014 04:43:46 AM
Southern Cross AXC choofer Smokstak Down Under 0 11-25-2009 06:28:07 AM
Southern Cross engines Rob Laurent Antique Engine Archives 1 03-24-2002 07:02:58 PM
