Kubota GL7000 No Output
this thread has 2 replies and has been viewed 306 times
Old 07-27-2019, 10:06:35 PM
alphabavo alphabavo is offline
Default Kubota GL7000 No Output
Good evening guys!
I managed to land a running Kubota GL7000 that looked like it was in great shape. Engine fires right up, runs great! However, there is no voltage output from the generator.
Here are the symptoms that I believe must be related...
Nothing shows on the voltage gauge.
12V charging circuit does not appear to be working, as battery voltage holds @12.5V while running.
Shutdown solenoid does not actuate when key is moved to shutdown position.
Any help would be greatly appreciated, You guys have come through for me in the past.
Old 07-30-2019, 08:16:17 PM
Default Re: Kubota GL7000 No Output
Update: Flashed the rotor by running a drill backwards, and am now getting a small amount of output. Thoughts?
Old 07-31-2019, 12:10:36 AM
AlanR AlanR is offline
This appears to be the manual:
https://www.absolutegenerators.com/m...ice_Manual.pdf
It devotes WAY more time to the engine than the gen end, but it would appear the prime suspects would be brush wear, failed AVR, or winding issues. I suppose a logical first step would be to do the resistance checks from the manual, then work from there.
Alan
Kubota/MeccAlte generator output issue. monoloco Honda, Yamaha, Kawasaki, Isuszu Generators 4 02-04-2019 09:15:36 PM
12v output on my Kubota LowboyII 7000? rideagiant Generators & Electric Motors General Discussion 7 06-12-2017 09:04:45 AM
Kubota ER-30 oldironcollector Vintage Diesel and Oil Stationary Engines 5 01-04-2013 09:01:33 PM
Kubota? TheToolman YouTube Old Iron Videos 2 10-16-2010 08:25:44 PM
