Homelite Generator
this thread has 22 replies and has been viewed 893 times
Old 09-07-2019, 06:25:49 AM
GeneratorGus's Avatar
GeneratorGus GeneratorGus is offline
Default Re: Homelite Generator
Angry Sailor and Vanman,
Both make sense. I went back and took a better look at mine, and they both have 3 lines involved in the fuel supply. Sorry for the sideways pics.
While I was poking around in that dark corner, I noticed this little rascal sitting there right next to the Simms D, Homelite Tank Heater/Generator, 32V. I couldn't crawl far enough into the hole to read the mod.#.
GUS
ID:	343343   Click image for larger version
ID:	343344   Click image for larger version
Old 09-07-2019, 07:39:21 PM
Gus your second picture looks more like my carb. From what I am gathering is that the air is lifting the gas like the aquarium filter used air to lift the water to the filter when I had tropical fish many years ago. Am I correct in assuming that the air lift goes into the fuel bowl and the threaded hole is the overflow. It seams to me that there would be a lot of air to get rid of , Down the overflow?? I tried to run the engine today , hoping that it would suck the fuel up using the choke. I fooled with it for over an hour. If I primed it I got it to pop , But not to run. Back to the drawing board. Ron
Old 09-08-2019, 06:30:47 AM
Ron, I thought about the aquarium bubbler. seems like a simple pump for a simple machine. The viscosity of the fuel vs water may have needed less air to do the lifting.
Also found another ad that says no batteries required, so they are direct service machines, but I forgot to look to see the output connection on my machines.
GUS
Another Homelite Generator John Newman, Jr. Generators & Electric Motors General Discussion 33 03-01-2011 05:29:39 PM
HomeLite Generator Jonathan Widelo Antique Engine Archives 0 07-04-2004 12:32:13 PM
Homelite XL Generator midnight Generators & Electric Motors General Discussion 0 03-17-2004 08:30:20 AM
PE-75-B Homelite generator Heath Daily Generators & Electric Motors General Discussion 4 03-14-2004 05:22:13 PM
old homelite generator steve lux Generators & Electric Motors General Discussion 1 04-28-2003 04:03:53 PM
