Old Homelite Generator Model 22D 120-2 Comes Back To Life
this thread has 12 replies and has been viewed 229 times
Old 09-01-2019, 12:50:32 PM
Gil Garceau Gil Garceau is offline
Default Old Homelite Generator Model 22D 120-2 Comes Back To Life
I got this at the Orange Engine Show 6 or 8 years ago, maybe more.
My recollection is something like when I found it with a $50 tag on it, I offered $25 and wound up with it.
When I got it home, I put in a little gas/oil 2 cycle mix and it would not start. I dribbled a little into the air intake and pulled again. This time it fired up and the lamp bulb lit up. This lasted all of 5 seconds until the little fuel in the carburetor was gone. I cleaned it up a little and put it away in a corner of the garage.
Fast forward...... I had recently been thinking I should drag it back out and make it run. First thing I removed the carburetor to get at the fuel pick-up. Top on the list of usual suspects is the check ball which is often found stuck after years of sitting. I found it stuck, popped it loose with a dental pick, cleaned it and put it back on the engine. 1 pull on the primer pump and.... this time it fired right up and kept running!
Then I cleaned a lot of the grunge off it, fired it one more time, took a couple pictures and put it away.
Update, I ran it for about 15 minutes the next day.
I am interested in learning more about it like age, catalog cuts, etc.
Enjoy,
Gil
ID:	342767   Click image for larger version
ID:	342768   Click image for larger version
My youtube channel: http://www.youtube.com/user/reddrryder/videos
The Following User Says Thank You to Gil Garceau For This Post:
Old 09-01-2019, 12:55:59 PM
Default Re: Old Homelite Generator Model 22D 120-2 Comes Back To Life
A few more pictures...
Old 09-01-2019, 09:16:04 PM
AngrySailor AngrySailor is offline
NICE! Iíve got one similar, canít remember the model off hand though... Iíve never run it, this put the bug in me to get her going. That 3600rpm scream probably good for mosquito control when mixed at the 10:1 I believe it specs!
Old 09-01-2019, 09:31:51 PM
The metal tag on the exhaust side of the fan calls for 24 to 1.
I am using 15 to 1.
It appears to shut down after running 5-10 minutes and won't re-start until it cools down for a while.
Old 09-01-2019, 09:50:15 PM
I havenít messed with mine and it may be different from yours so just a couple guesses... does this use that ďpressure fuel tankĒ setup? Is the cap gasket good? Do you have spark after it stops? Does the engine turn free still? I remember reading that these were prone to main bearing/crank seal issues. The bearing would wear and affect the point gap. Again Iím not real familiar with these little beasts... also I think these have a bushed small end on the rod (no needle bearings) so be real generous with the oil...
Old 09-01-2019, 10:03:28 PM
Right after it quit I pulled the plug and it still had a good spark. Plug was clean and dry.
I even put a few drops of fuel oil mix into the cylinder before replacing the plug.
Old 09-01-2019, 10:13:08 PM
Nice! It's one model off from the old Homelite I'd like to find. I'm holding out for a model 23a.
Robert
Old 09-01-2019, 10:27:15 PM
Found a couple old pics of mine from a couple years ago. I think itís a 24a? 110v. I was told it ran from the fellow whoís scrap pile I pulled it from, then never had the time to mess with it. I do remember it wasnít particularly ďliteĒ when I put it in the back of my truck though
ID:	342820   Click image for larger version
The Following 2 Users Say Thank You to AngrySailor For This Post:
Old 09-01-2019, 10:31:52 PM
I believe the 24A is an AC generator.
Old 09-01-2019, 11:12:52 PM
Yes, that one is 110v 60hz @ 3600. I believe some Of these were homelites were odd frequency for aircraft, 400hz? I’m not entirely sure about that though...
Old 09-02-2019, 12:50:14 AM
Vanman Vanman is online now
They made 180 cycle, 3 phase, 230 volt ones for running special power tools.
Here's one here. Just move the decimal point on over!
https://inlandempire.craigslist.org/...966266660.html
Old 09-02-2019, 01:21:10 AM
Had some more fun today..
Here's another video.
Enjoy!
Gil
The Following 3 Users Say Thank You to Gil Garceau For This Post:
Old 09-02-2019, 12:08:04 PM
The model 23a is AC 115v 15 amps. The model 24a is 115v 20 amps. Both generators are 60hz line frequency.
Robert
Model 31 washer back to life Dustin D Ehli Maytag Engines and Collectibles 1 10-09-2016 08:51:27 PM
Homelite generator model 25A 120/230 narrapierrr Generators & Electric Motors General Discussion 35 02-19-2013 08:06:22 AM
economy model s back to life Tim Rostar Hit & Miss Gas Engine Discussion 1 09-29-2012 09:09:09 PM
Lehmann M1867 model is back to life stirlingmaier Hot Air Engines 5 03-18-2011 03:29:22 PM
Clinton model 351jov Back to life ecb223 Small Air Cooled Gasoline Engines 2 01-08-2011 04:56:49 PM
