Onan 12MDJC-3R/2268D Serial #16c859299 White Smoke
this thread has 93 replies and has been viewed 3981 times
Old 01-08-2018, 04:09:03 PM
sscummins sscummins is offline
Default Re: Onan 12MDJC-3R/2268D Serial #16c859299 White Smoke
Here are a couple pics of quantity of smoke FYI
ID:	300071   Click image for larger version
Old 01-08-2018, 04:12:15 PM
Billy J Shafer's Avatar
For the last time. Set the timing by the flow method. It will give you the correct timing.
The Following 4 Users Say Thank You to Billy J Shafer For This Post:
  #43
Old 01-08-2018, 05:26:35 PM
Motorhead's Avatar
You could use that for Mosquito abatement ....... until the tree huggers caught up with you.
My 1939 WILLYS Pickup.
Bought in 1971
Old 01-08-2018, 06:30:33 PM
zuhnc zuhnc is offline
Agreed; use flow timing on the PSU pump. It would probably be a good idea to remove the injection pump and verify that the cam lobe is down and toward you at the PC mark on the flywheel. At this time you can verify that the shim pack thickness is as stamped on the block, and the o-ring seal is on the pump body where it meets the block. Put the pin in the pump side and secure the pump. Follow the flow timing method (after removing the delivery valve, and then calculate the required button thickness per the instructions in the manual. Remove pump and change button, and then do it all over again to verify results. Once you are ABSOLUTELY certain the pump is timed right - follow the manual - then your smoking issue is most likely low compression due to leaking valves or worn rings/cylinder. Set valves cold, remove ALL injectors and then check compression. A very tiny air leak will give you erroneous results. Disconnect the governor link to the fuel pump to "disable" the injection pump. zuhnc
The Following 2 Users Say Thank You to zuhnc For This Post:
  #45
Old 01-08-2018, 07:09:42 PM
No worries Billy, I am at work and I cant just jump on it doing the flow timing, besides I am not familiar with this and trying get as much knowledge from everyone kind enough to help with their knowledge. Sorry if my lack of knowledge and desire to know more gets people on edge.
Thanks everyone, I will do the flow test when I get the time, I will keep all posted when done.
Thanks again for all of everones help. have a good night.
Steve
Old 01-08-2018, 07:21:28 PM
alco539 alco539 is offline
Just reading over this entire thread the initial post really just stood out to me. If you are confident in the compression numbers then that is what I would expect the problem to be. Every IDI diesel I have ever worked on the minimum compression numbers are normally going to be closer to 400...
I'm really surprised you can even get it to start with those numbers.
Definitely check/correct the timing via the flow method until you are confident that it is dead on, but I fear you may find that compression is the issue if those numbers are accurate.
Jimmy
The Following 3 Users Say Thank You to alco539 For This Post:
  #47
Old 01-08-2018, 07:50:14 PM
I concur; indirect injection pressure should be no less than 350 or so. I see from post #18, your highest pressure is 278, and lowest is 210. That is too great a variance. Also, you have the PSU 4-cylinder injection pump and you must flow time it. (easier for us "hobby" mechanics) The "air timing" procedure is only for the 2 cylinder Brice-Kiki pump. You should do a leakdown test with the proper equipment. Set and check valve clearance first. The leakdown test will tell you where the problem is - rings or valves. If ether has been used, probably broken rings or pistons. My 1968 MDJB has about 400 psi on both cylinders; one has new rings, the other has used rings. Starts easily after the requisite preheat, and has no black or white smoke at any load. zuhnc
  #48
Old 01-08-2018, 09:25:33 PM
Motorhead's Avatar
Jimmy
I had the early VW non turbo diesels and the compression on it was around 460 psi cold. Now the older Mercedes diesels would start and run well with the compression in the low to mid 300 psi range. 210 is way too low with normal starting RPM.
Bought in 1971
  #49
Old 01-08-2018, 10:56:10 PM
BigBlockChev's Avatar
I have seen J series diesels with numbers in the 250~275 psi range work fine. The amount of smoke and to some extent the rapid heating up of the engine suggest that it is not a compression issue to me . I have also measured other diesels like Westerbeke with compression in the 550 psi range. If the injectors arenít stuck open or set way too low then I am still thinking the timing is off by a significant amount. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following User Says Thank You to BigBlockChev For This Post:
  #50
Old 01-09-2018, 09:18:18 AM
Thanks everyone, I really appreciate that everyone is so helpful, dont know how I would go about it without ??????, I will check the timing by flow method asap. I regred that it probably wont happen for another 2 weeks, with work doing 12+hrs vacation coverage and leaving for a week next week, I know wah wah wah. LOL I should get back at it full force after I get back following next week.
Thanks again to all
Steve
12mdjc-3r/2268d s/n 16c859299 sscummins Onan Generators 0 08-02-2017 02:47:17 PM
Allis Chalmers/ Onan 685T engine white smoke gen51 Multi-Cylinder Stationary Engines and Power Units 4 02-27-2013 11:10:10 PM
Onan 12MDJC-3r/2268d 120 output only? Tburk49760 Onan Generators 5 12-07-2011 10:36:21 AM
Onan 12.DJC-18R Lots of white smoke? checkpoint Onan Generators 13 02-07-2010 05:49:00 PM
I have white smoke baroling out of my Onan Emerald 1 genset philboy83 Onan Generators 7 01-11-2010 01:34:13 PM
