I have white smoke baroling out of my Onan Emerald 1 genset
this thread has 7 replies and has been viewed 7774 times
Old 01-07-2010, 01:15:31 PM
philboy83 philboy83 is offline
Default I have white smoke baroling out of my Onan Emerald 1 genset
My onan genset /emerald 1 generator, model 4.0BGE-1R/26100A is smokeing thick white smoke. It was still running when I shut it down. I belive that it just started burning oil extensively. How can I fix it with mim cost.
Thanks Phil
Old 01-07-2010, 03:19:53 PM
Ray Cardoza's Avatar
Default Re: I have a white smoke baroling out of my onan genset/emerald 1
maybe over filled with oil ? or worn rings. check the oil level is what id do first
Old 01-07-2010, 04:54:55 PM
Unhappy Re: I have a white smoke baroling out of my onan genset/emerald 1
Ok the hole story. This last weekend I over field the genterator with oil. It did not start intill I drained it out. It ran for 2 or 3 hours before I stop for the night. The next morning I started it and almost as soon as it started the smoke came out of the excause thick white and strong. It ran for at lest 5 to ten mim be for I shut it down. What is the next move.
Phil
Old 01-07-2010, 06:25:49 PM
Patrick Patrick is offline
Run it for longer, under full load - your breathers etc. are probably full of oil, which will burn off once you get it good and hot for a while...
Old 01-07-2010, 06:31:35 PM
Kimbra Dean Kimbra Dean is offline
Default Re: I have white smoke baroling out of my onan genset/emerald 1
Have you checked the oil level since this happened. Just wondering if maybee the float valve in the carburetor may have stuck and let gasoline continue to trickle into the engine and find it's way into the crankcase.
Old 01-07-2010, 06:33:56 PM
Exclamation Re: I have white smoke baroling out of my onan genset/emerald 1
There probably is oil hung up in the valve galley, and you still may have too much oil in the crankcase! Also, are you using the proper grade of oil?
I would drain the oil, and re-fill to the low line on the stick. Clean out the crankcase breather, and air filter of any excess oil. Start the engine, and see if the oil smoke clears after 10 to 15 minutes. If it does, fill to proper level, and you are good to go. If it still smokes, I would look for any place where oil could have puddled when the engine was overfull, and see if the engine is pulling the lube oil into the intake. Make sure the engine is leveled properly. A tipped engine may splash enough oil to a place where the engine can pull it thru the intake!
Old 01-08-2010, 08:29:43 AM
shipsmate shipsmate is offline
Default Re: I have white smoke baroling out of my Onan Emerald 1 genset
Check to make sure the breather check valve isn't stuck closed.
Old 01-11-2010, 01:34:13 PM
I removed it on to my bench. I have taken the air, excause manafold, and the carb off before I got any replies. I found what looks like haft of o-ring or seal inside of the intake. The plugs look black, one looks wet. Before I put it back together and try to run it is there anything else that is simple to check at this point.
Onan Emerald One Genset (no AC output) Help! passnbyu Onan Generators 16 02-04-2018 01:10:49 AM
60KW w/ Allis Chalmers White Smoke crbearden Onan Generators 20 04-13-2010 09:30:39 PM
MDJE - Lots of White Smoke dondandd Onan Generators 21 12-12-2009 09:02:58 PM
Smoke, Smoke, Smoke from MEP-003A on first time start-up djwils285 Military MEP and Aircraft Gen-Sets 8 06-13-2009 09:39:50 PM
17.5RDJF diesel with white smoke oliver Onan Generators 19 05-05-2009 07:54:58 PM
