this thread has 4968 replies and has been viewed 330127 times
Old 01-21-2019, 02:30:15 PM
trukinbear trukinbear is offline
Default Re: What Have You Done to Your Onan Generator Today?
Walked around my garage, did a quick inventory. 13 generators, and I'm not a shop...
ONAN
2.5AJ
2.5AJ
4BFA
4BFA
4BGEFA
4BGFFA
5BGA
6MDJE
7.5HDKAL
10HDKAG
12DJC
KOHLER
15R15
TROY BILT
5550
Old 01-21-2019, 02:44:01 PM
Originally Posted by trukinbear View Post
...I'm not a shop...
Yes, you are. Denial is common in the beginning.
The Following 3 Users Say Thank You to Wayne 440 For This Post:
  #4873
Old 01-21-2019, 03:20:00 PM
Admitting you have a problem is the "first step" to recovery. I know, I have walked in your shoes.
It is a rough road, but now that I have been "cured", I can see that I was worth the trek. Good luck on your journey
Old 01-21-2019, 03:32:48 PM
Originally Posted by Max Thompson View Post
...now that I have been "cured"...
Just keep telling yourself that....
  #4875
Old 01-21-2019, 03:41:36 PM
Nice collection
I'm ahead so far... the first 2 sales (5BGAL, and 7.5JB) paid for all of these, the fuel to go get them, and food/lodging along the way. Plus I've made some of my impoverished neighbors lives a little brighter (literally) along the way. I can't complain about the Onans in my garage.
Old 01-21-2019, 05:49:18 PM
That was "before". That mess is all cleaned up, and Neva can park her truck in that spot. I only have 2 Onans running at this moment, one in the driveway and one in the shop.
Pulled a dump a$$ stunt with the DJB. I had been test running it with no air filter and decided to put one on it. Grabbed a base, cover and new air cleaner from the parts stash. Problem was I got a "full size" base that should have a cover that a hose from the air heat option goes onto which is not what I installed. I also took the tank to town and filled it. Hooked the fuel hoses back up and fired it up. Ran Like $hit. I figured I had air in the lines and spent several hours trying to "fix" that, I had forgotten I put the air cleaner on since it had run last. Found a proper air cleaner base and all is well.
I have preached before, only "fix" one thing at a time, even refueling. It really narrows down the possibilities when things go wrong.
I'm ahead so far...
You NEVER get "ahead". Kind of like gambling, you will always be in the hole in the end.
Old 01-22-2019, 03:55:47 PM
Longshot1 Longshot1 is offline
Installed Pertronix Ignitor in my 1970 45EM gasoline powered Onan. Part #1261. That part number is for a distributor with a hollow shaft. Solid shaft takes #1266. Took all of 20 minutes to remove old points/condenser and install Ignitor. It was 27 degrees and the generator started immediately. It runs better now than it ever has. $75 well spent.
The Following 2 Users Say Thank You to Longshot1 For This Post:
  #4878
Old 01-22-2019, 05:05:00 PM
Max, do you still have the cck in the picture with the rear fuel tank? Never seen one setup like that.. any pictures?
Old 01-22-2019, 05:21:17 PM
TLB01 TLB01 is offline
The rat gen self-destructed today. I was attempting a monthly run and the engine let go. Not going into details, but I think I am done with generators.
Old 01-22-2019, 05:30:41 PM
Ouch. IIRC, that is (was?) a DKD.
