Onan DJE Running Away
this thread has 27 replies and has been viewed 1113 times
Old 11-01-2017, 11:13:29 PM
John Deere 123 John Deere 123 is offline
Default Onan DJE Running Away
Hi everyone, I'm having trouble with my onan dje gen set. It ran fine for 3 hours then suddenly started running away and blowing lots of smoke, I had to block the intake in order to shut it down. I took the injection lines off and moved the linkage to the off position and fuel still came from one injection pump port so I'm guessing my pump stuck. Every thing seems to move freely on the pump. It sat for 7 years with out running. Injection pump is zexer made under Bosch. What is wrong? Any help Would be greatly appreciated.
Old 11-01-2017, 11:16:08 PM
Billy J Shafer's Avatar
Default Re: Onan dje running away
Most likely pump needs an rebuild.
Old 11-01-2017, 11:26:11 PM
I'm confident I can take it apart but just trying to figure what could be the problem in the pump. Its only the one side I believe
Old 11-02-2017, 08:02:15 AM
The only other thing is a gov problem.
Old 11-02-2017, 09:29:38 AM
I held throttle linkage in the off position and it still was running on one cylinder I believe. But I'll check the gov
Old 11-02-2017, 11:37:12 AM
Default Re: Onan DJE Running Away
How much head pressure is the fuel at the pump inlet or how much pressure is your lift pump? "Fuel still flowing from one injector line" that could be normal if the pump is in bypass, it would have to overcome the spring in the delivery valve though and your injector would have to be stuck open or spring broken to flow fuel, also combustion pressure would be coming out the injector inlet if that was the case. Turn the engine with the injector lines off and see if fuel stops and flows from another pump. Also check it's not getting crankcase oil from anywhere or even an oil bath air cleaner can cause a runaway.
Old 11-02-2017, 12:41:12 PM
I forgot you said that. Yes i would check the fuel system or for running on oil.
Old 11-02-2017, 01:08:57 PM
I started it again today and it ran away again but this time I shut it down by loosening the injector lines. One injection line had no affect (no fuel came out) the other injection line shut it down. Not sure on fuel psi but it is pumping fuel.
---------- Post added at 01:08:57 PM ---------- Previous post was at 01:02:41 PM ----------
Oil level is right, has a paper air filter and I un hooked the crankcase breather from the intake manifold and still ran away again so I'm guessing something is in the injection pump. Maybe varnish could be the culprit?
Old 11-02-2017, 01:13:37 PM
It sounds like it has a break away rack inside the pump and one barrel is stuck full delivery
Old 11-02-2017, 01:19:13 PM
That is what it acts like. I'm hoping nothing broke. It was under no load when it happened.
Onan JB and running AC squidtrap Onan Generators 16 07-23-2017 10:21:54 PM
got my onan otc running YellowLister Onan Generators 4 09-09-2013 05:52:07 PM
Another Onan CCK up and running pnora Onan Generators 8 04-20-2013 11:42:18 AM
Onan 1.0 AJ up and running! TomCarrington Onan Generators 2 04-01-2013 12:58:36 PM
Onan BFA Running away 5th Wheel Travler Onan Generators 6 08-19-2010 09:42:45 AM
