Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Lifting and Loading
Lifting and Loading Pay loaders, Fork lifts, tow motors, jacks and hoists.
Lifting and Loading
Daewoo Forklift - Lift Cylinder Repair
this thread has 32 replies and has been viewed 1545 times
Old 03-30-2018, 11:13:32 PM
Heins Heins is offline
Default Re: Daewoo Forklift - Lift Cylinder Repair
I was wondering if it was going to clear the chain and hoses.
Old 03-31-2018, 09:23:39 AM
When you had the gland nut off, did you see how much smaller the dia of the ram is than the ID of the barrel is? That is why the oil can get to the bottom end of the ram.
Old 03-31-2018, 10:45:49 AM
Now that everyone knows how a single acting cylinder works, it is time for a quiz.
How do you replace the seal in this cylinder? It has a wiper seal and an "0" ring to seal the oil in the cylinder.
Old 03-31-2018, 03:24:21 PM
Clearance between chains and cap is very close, I was not sure it was going to work until I got the chains/hoses back in place. Had a friend watch it closely as I raised/lowered it a few times, one of the chains barely touches it, but not enough to worry about. If I had to do it again, I would have left center hole in cap a little bit smaller and pressed it onto rod. Stainless started work hardening and last cut ended up a wee bit larger dia than I had planned.
There was 1/4" to 3/8" gap between cylinder and rod, and to my surprise gland nut is solid brass. All in all it was an easy fix, certainly much easier than pulling the whole cylinder. My only gripe is the backup ring for the O-ring on OD of the gland nut, why can't they make those things out of something with a bit more flexibility? I put it in hot water, carefully got it over threads, then had to get it over a lip before it would go into groove, of course it broke. Used the old backup ring, it was broken too but less deformed, so far it is not leaking.
As for the quiz, let me guess, it is welded and the only way to rebuild is to cut it apart? Second guess would be one of those wire circlip things that you have to pry one end up then pull out of the groove with some side-cutters pretty much destroying it in the process, those are lots of fun too!
Old 03-31-2018, 06:04:19 PM
It is a welded cylinder, but you don't have to cut it apart and no circlip. Try again.
Old 03-31-2018, 06:29:37 PM
Pry out with a pick and try to shove them back in without tearing. If its double acting, and welded, how would you replace piston seal short of cutting it open?
Old 03-31-2018, 09:49:12 PM
It is a single acting cylinder, the ram will come all the way out so you can replace the "O" ring and the wiper seal. It doesn't have any seals or cup on the lower end like yours.
  #28
Old 04-01-2018, 11:56:05 AM
Here is a hint.
Old 04-01-2018, 12:08:56 PM
Troll's Avatar
Troll Troll is offline
Rebuilt my pallet jack with no piston on the ram. Didn't even have a gland to remove at the top. Just pulled the ram out by hand, dug out the seals with a pick, rolled new seals in, greased them up and pushed the ram back in. Took all of about 10 minutes including cleanup.
Rebuilt my Hyster last month and wasn't quite so easy, or lightweight:
Repacked every cylinder, replaced every wear bearing and slide pad, and had to retube one lift cylinder. Good and strong with no leaks now.
ID:	307082   Click image for larger version
ID:	307083   Click image for larger version
ID:	307084   Click image for larger version
The Following User Says Thank You to Troll For This Post:
  #30
Old 04-01-2018, 01:51:12 PM
On your pallet what kept your ram from blowing out of the barrel? It probably couldn't travel far enough.
OLD Diesel Fork Lift Cylinder Packing Jamie Darian Brown Lifting and Loading 7 02-07-2018 09:21:29 AM
CASE Terra-Lift M-3 Fork lift on tracks Tom Street Lifting and Loading 0 06-04-2017 09:38:38 PM
Pettibone-Mercury GS-60 Forklift Mast Cylinder tempered-flame Lifting and Loading 0 06-21-2016 02:08:45 PM
Ford NAA lift system repair and rear pulley uglyblue66 Antique Farm Tractors 7 02-15-2015 02:16:24 PM
Clark Forklift Hydraulic Problem, no flow to cylinder reservoir dalmatiangirl61 Lifting and Loading 16 01-12-2012 03:46:20 PM
