Lister D mag
this thread has 1 replies and has been viewed 230 times
Old 01-19-2019, 01:46:14 PM
Jonbouy Jonbouy is offline
Default Lister D mag
Hi everyone,
I have taken the mag off my lister D to give it a good clean and remove the rust from the spacing plates that go under it.
I forgot to mark the cogs though when I removed it!!
Does this matter as I havenít played with the timing side of the engine, or have I?
Does the mag need to go back in a certain position with regards to the points or can it be bolted back and the chain put on it in any position?
I have tried googling this but canít find any reference to the position of the mag to the engine.
I am guessing that as long as itís spinning, itís send current to the points and they just take it as needed.
Hopefully I havenít done anything serious that will cause the engine not to fire at the right time and give me loads of work moving the mag one chain link at a time until I get it back to sparking at the right time.
Please someone give me good news!!
Old 01-20-2019, 09:10:15 AM
oldgoat oldgoat is offline
Email NOT Working
Default Re: Lister D mag
There are about 3 youtube videos on setting the timing. A video is worth a thousand words.
Lister SR 2 farmgate Lister Engines 7 12-15-2017 03:01:28 PM
Lister 3 hp + lister dynamo 19fingers55 Smokstak Down Under 17 01-01-2015 03:18:52 AM
Lister 4kw onan adapted to Lister Iwasthere61 Onan Generators 3 01-31-2013 11:36:54 PM
Lister 12/2 30kw koler generator head COOLING The Lister????? mytickets Vintage Diesel and Oil Engines 2 04-12-2010 04:34:18 PM
Need Lister ST Hat glfarnes Vintage Diesel and Oil Engines 0 09-25-2007 04:53:53 AM
