Vintage Construction Equipment Graders, Shovels, Fork lifts, Dozers & Crawlers, Pay loaders & Fork lifts
Home Made Rock Crusher advice needed
this thread has 5 replies and has been viewed 1359 times
Old 07-21-2017, 05:33:49 PM
threehitsandamiss threehitsandamiss is offline
Default Home Made Rock Crusher advice needed
Hello all,i want to make a rock crusher and im looking for advice to build one on a budget,was thinking of using some 3-6hp gas engine flywheels,for my first crusher build and machining the crank shaft with the right offset for the adjustable jaws,if you have made one and would like to share some ideas i would really appreciate it ,thanks.
Old 07-21-2017, 10:28:45 PM
Default Re: home made rock crusher advice needed
Think you might want to check out trip hammer crushers first. Other types require seriously hard (aka expensive) steel. Trip hammer types just use a cam to lift and let go (drop) big steel rods or bars. Such bars can be hardened on buisiness end with hardening welding rod.
Doc
This space For Rent... (hey, worth a shot.)
Old 08-02-2017, 08:55:54 PM
Bigoldtractor65 Bigoldtractor65 is offline
We made a crusher using an old hay baler. Crusher was homemade using 1" thick T1 plate. I'll try posting pics.
The Following User Says Thank You to Bigoldtractor65 For This Post:
Old 08-02-2017, 09:04:18 PM
We've crushed many tonnes of rock. 25 hp tractor is all that is required.
ID:	287779   Click image for larger version
The Following 3 Users Say Thank You to Bigoldtractor65 For This Post:
Old 08-23-2017, 01:21:32 PM
mike french mike french is offline
bigoldtractor65 Id love to see some more pics of yours! Thanks !
Old 08-31-2017, 04:50:56 PM
Default Re: Home Made Rock Crusher advice needed
More pics I hope.
ID:	289945   Click image for larger version
home made rock crushers threehitsandamiss Antique Gas Engine Discussion 4 07-23-2017 09:12:32 AM
Little rock crusher Andrew Mackey Farm + Industrial Antiques and Collectibles 0 03-15-2014 01:39:41 PM
Home made head gasket help needed madmowerz Small Air Cooled Gasoline Engines 3 10-29-2011 09:38:09 PM
Is this a rock crusher? Firewoodguy Farm + Industrial Antiques and Collectibles 11 06-14-2010 01:11:53 PM
Rock Crusher darrin Antique Gas Engine Discussion 2 10-15-2007 08:01:18 PM
