Picture of Early Homebuilt Tractor
this thread has 11 replies and has been viewed 2995 times
Old 07-02-2009, 01:07:11 AM
OTTO-Sawyer's Avatar
Default Re: Picture of Early Homebuilt Tractor
Originally Posted by Kent McMakin View Post
Hey Ironman. The Model A engine, when modified correctly does just fine. At least as good as a Rotax chain saw engine. And it sounds a whole lot cooler too.
Of course it helps to know how to keep a Model A or Model T engine running right too.
Anyone can turn the key and fire up a volkswagon or a chainsaw.
As for that tractor if you can call it that, it's definitely not a Model T engine, the manifolds are on the wrong side. I haven't looked at a Model A recently enough to remember if they switched sides or not, but I don't think it's an A either.
Old 07-02-2009, 03:22:03 AM
Eric M. Eric M. is offline
Definitely not an A. The block design is different, the water manifold isn't found on A engines, and the manifolds are on the wrong side. This almost looks like a 4 cylinder marine engine...
The Following User Says Thank You to Eric M. For This Post:
Early tractor air cleaners Scott Vassar Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 11 02-02-2009 02:21:26 AM
Homebuilt tractor help please! Justin D. Antique Farm Tractors 7 06-21-2008 12:15:59 AM
Homebuilt Tractor JBailey Antique Farm Tractors 41 05-12-2008 09:03:19 PM
Early Graham Tractor Gasengn Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 01-14-2007 10:22:29 PM
Early IHC Scale Tractor Paul Spence Scale Model Engineering 2 09-15-2006 09:22:08 AM
