What kind of rear end is this?
this thread has 6 replies and has been viewed 1754 times
Old 07-18-2009, 03:57:28 PM
JKWidener JKWidener is offline
Images: 26
Default What kind of rear end is this?
This rear end is in my dozer. You can see pictures and info at this link. http://www.smokstak.com/forum/showthread.php?t=63300
Old 07-18-2009, 07:25:29 PM
Jon Nessel's Avatar
Jon Nessel Jon Nessel is offline
Default Re: What kind of rear end is this?
Almost looks Dana'ish, or Spicer for that matter. Kinda like the 1 ton pickup truck stuff.
The Following User Says Thank You to Jon Nessel For This Post:
Old 07-18-2009, 08:39:47 PM
Well my suggestion was going to be be that if you have a Victor gasket catalog or at least one say 10 years old they used to have a picture of gaskets for truck rear ends. Then you could match the picture with yours and see what you have. I also looked in an older Motors Truck book and for the Studebaker rear ends it hints they were Spicer (Dana) units. It also said for the larger units go to either the Rockwell (Timken) or Eaton axles sections in the manual.
The Following User Says Thank You to John Schwiebert For This Post:
Old 07-18-2009, 09:09:26 PM
DennisFust DennisFust is offline
it looks like it could be out of a older ih scout built in the 60s or a american motors the way the hubs look.
The Following User Says Thank You to DennisFust For This Post:
Old 07-19-2009, 04:39:04 PM
Can't speak to older or newer Victors, but my Victor Gasket Guide #12, May, 1938, appears limited to illustrations of selected engine gaskets only.
That catalog lists first Victor Gasket Guide as 11-1922 issue,, with subsequent issues in 24, 26, 27, 28, 29, 30, 31, 32, 34 and 36. Sounds like they slowed down in the Depression; I assume they went back to annual issues later.
The Following User Says Thank You to Bud Tierney For This Post:
Old 07-19-2009, 04:50:04 PM
have you had the back cover off there should be a part number on the outside edge of the ring gear or inside on the flange were the ring gear bolts to the carer.if you have not had the rear cover off yet and the dozer has ben sitting if the grease is still in it th ring gear and pinion might be rusted at the grease leavel.
Old 07-20-2009, 06:04:35 PM
Images: 26
Found out that the rear end is out of a 1954 Studebaker Champion. Of course it has been shortened. Thanks for the help.
10-20 Rear Axles Rex Piekarczyk Antique Farm Tractors 0 08-26-2008 05:52:39 PM
Propane in the rear! TheGandy Onan Generators 1 04-25-2008 11:49:47 AM
rear fenders 31 JD GP B.L. Rodenkirch Antique Farm Tractors 0 08-20-2006 11:44:16 AM
Huber HK rear rim? Tommy Stojanov Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 07-10-2006 08:36:17 PM
JD 110 Rear Ends Skip Rogers Antique Engine Archives 2 06-09-2003 06:44:32 PM
