Scale OilPull Build - About 3/8 Scale of a Heavyweight
this thread has 15 replies and has been viewed 2023 times
Old 05-16-2018, 01:19:48 PM
wagswitte wagswitte is offline
Default Re: Scale OilPull Build - About 3/8 Scale of a Heavyweight
I work at a fab shop too, anything i need i can usually get here i do have things i can use at home when Iím not at work and a friend of mine helps me out once in awhile dropping stuff off he thinks i might use.
Old 05-25-2018, 04:49:02 PM
decoy64 decoy64 is offline
Sorry I've been a stranger lately I haven't had any time to work on this little guy for a while. Hoping to have quite a bit of time this weekend to devote to it. More pictures will be coming after that
The Following 3 Users Say Thank You to decoy64 For This Post:
Old 06-08-2018, 11:38:52 PM
You all were probably thinking this thing died as just a frame... I have been super busy lately. (Always seems to happen when you have something you WANT to work on...)
Got some work done on the clutch assembly tonight. I will try to post pictures tomorrow of where I got tonight, and where I get tomorrow. I should have the most of the day to dedicate to working on it. Still don't have my wheels yet, but the guys in the fab shop at work are supposed to be hooking me up with the outer rims rolled to my dimensions. I have been on the road for work for the last 2 weeks, so I haven't had the opportunity to harass them about it
More to come...
-Griffin
The Following 2 Users Say Thank You to decoy64 For This Post:
Old 06-10-2018, 05:57:24 PM
Here's the pictures, a day late... I got the engine roughly positioned and a good portion of the clutch parts made. I still need to finish the clutch shoes and throw out bearing. Hopefully I will get some news of the wheels being done this week at work. First pic is to show kind of how the clutch is going to work.
ID:	312243   Click image for larger version
ID:	312244   Click image for larger version
The Following 5 Users Say Thank You to decoy64 For This Post:
Old 06-16-2018, 06:41:12 PM
Getting some more done on the OilPull today. Got the rings for my wheels this week, and am working on getting them built today. I will post pictures when I have some to post.
-Griffin
Old 08-05-2018, 02:35:56 PM
Thought I would see if you got anything done on your build,I know you have probably been busy just thought I would check in.
The Following User Says Thank You to wagswitte For This Post:
1/2 Scale Aermotor Build JFleury Scale Model Engineering 73 05-20-2018 03:24:48 PM
Scale model oilpull wagswitte Scale Model Engineering 156 06-06-2014 10:35:45 PM
Scale Oilpull Plans? wagswitte Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 10-26-2012 05:32:38 PM
Scale build-up in head shoptek Antique Gas Engine Discussion 8 01-02-2009 09:55:22 PM
1/2 or 5/8 scale engine build GHammer Steam Stationary Engines, Traction Engines, Steam Boats 33 12-02-2008 03:01:48 PM
