Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
Holt Engine Casting Set
this thread has 27 replies and has been viewed 10561 times
Old 12-07-2012, 10:44:03 PM
CaptainJohn CaptainJohn is offline
Default Re: Holt engine casting set
Don, what ignition are you going to use. Thanks Capt,n
Old 12-31-2012, 12:26:33 AM
DLM DLM is offline
Hi John
I am using coil point & condenser it works ok Don
Old 01-24-2013, 04:25:56 PM
niceonetidy niceonetidy is offline
Does anyone have a complete set of prints they would like to sell please?
Colin
Old 08-15-2013, 02:54:02 PM
Capt...John Capt...John is offline
Photo Re: Holt engine casting set
I have 2 sets of prints. I may sell one set. Got to keep the other set just in case I finish my Holt engine or sell it. It is over 80% done.
Old 09-09-2013, 01:00:06 PM
Ventrac4131 Ventrac4131 is offline
All;
I am new to machining, but not engines, is the Holt Engine something a beginner could Tackle? If not would it be possible to get a copy of a set of Drawings as I want to make one out of wood, Ido detail woodwork and furniture building and i am a Holt nut, I am also looking for a set of Holt 75 Drawings
Best regards
Eric J. Hovan
ENC(SW/AW/Fleet Diesel Engine Inspector) USN Ret
Old 09-09-2013, 02:16:44 PM
gbritnell gbritnell is offline
Hi Eric,
It's certainly not something that a beginner would want to tackle. As far as making one from wood you would be better off making one from photos as the model engine isn't an exact copy.
gbritnell
Old 09-09-2013, 08:45:14 PM
Mike N Mike N is offline
I decided that the construction method for the main bearing machining was crude to say the least but with the way that it was cast you didn't have much choice.
Wire EDM! is the best way to get the main bearings cut!
Old 09-09-2013, 09:23:27 PM
Arrow Re: Holt engine casting set
Originally Posted by gbritnell View Post
Hi Eric,
gbritnell
George, your Holt engine is nice looking, but not by any means a exact copy. You took the easy way with a cnc made split crankcase & many of the parts are made with bar stock. That makes it easy to hold each part as it is machined. When built from a casting kit, the parts are much harder to hold in place too machine. No easy flat surface to start with. The looks is nice but far from the model engine it is modeled after.
Old 09-10-2013, 07:19:00 AM
As Mike N stated the main bearing construction is crude and somewhat inaccurate to say the least. That was the reason for me making mine with split crankcases.
John, I didn't design the engine but rather built it to the drawings. Whenever a miniature engine is built there has to be some liberties taken to make it work. The original Holt probably had a magneto on it and there certainly wouldn't be any way to replicate that on this size engine.
gbritnell
Old 09-10-2013, 10:59:05 PM
Here is a Holt engine made from a casting kit...see video.
http://www.youtube.com/watch?v=AjQLKLaDOTY
Need Help to Finish a Holt Engine Capt...John Scale Model Engineering 0 06-16-2016 02:54:40 PM
NEED Holt engine data Capt...John Scale Model Engineering 23 04-02-2015 08:18:23 PM
Holt 120 hp 6 cylinder engine Steamrguy Multi-Cylinder Stationary Engines and Power Units 2 06-07-2013 03:09:15 AM
Holt 120 engine D Rutherford Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 10-21-2010 02:07:16 AM
45 HP Holt Engine oldsalt Dozers and Crawlers 1 06-22-2008 09:42:48 AM
