Wisconsin Engines
1964/5? Wisconsin AENLD 9hp King Midget
this thread has 23 replies and has been viewed 1982 times
Old 11-14-2016, 09:35:07 AM
Jarney Jarney is offline
Default 1964/5? Wisconsin AENLD 9hp King Midget
Hello all, working on a King Midget car for a coworker. It has a Wisconsin AENLD 9hp motor in it - pretty neat little car. I'm wondering if anyone can tell me how to get the drive (clutch) assembly off? It is threaded on and I don't see a good way to hold everything still while unscrewing it. Plus it's rusted and I'm trying not to break anything since it's a little old and brittle. I can post some pics if that is ok at this point. I'm just not that familiar with this sort of setup. I worked at a golf course for some time, but this is not like any of the golf carts we had. Any help is appreciated. Thanks. Later.
Old 11-14-2016, 12:53:35 PM
Chris M Chris M is offline
Default Re: 1964/5? Wisconsin AENLD 9hp King Midget
You can take out the spark plug and put a clean starter pull rope down the hole then slowly turn engine over until it stops. This is how I remove flywheels on just about all the small engines I work on.
Old 11-17-2016, 08:42:38 AM
Thanks Chris M, I'll give that a try when I get a chance. Later.
Old 11-17-2016, 09:05:24 AM
Here's a pic of the motor area. Later.
Old 11-17-2016, 04:41:35 PM
No luck with the rope trick, I'll try to get a better pic posted when I get a chance of the assembly I'm trying to remove. Thanks for the ideas though. Later.
Old 11-18-2016, 11:01:30 AM
Ok, don't know if this will help but here is a pic of what I'm trying to remove. Thanks. Later.
ID:	268307   Click image for larger version
Old 11-18-2016, 11:41:06 AM
Gasenginegangster Gasenginegangster is offline
Thumbs up Re: 1964/5? Wisconsin AENLD 9hp King Midget
Try posting on the King Midget car club site. Lot of info on there.
Old 11-19-2016, 10:21:52 AM
My next stop - hahaha - thanks for the help and ideas guys. I enjoy seeing the pictures of the old stuff on the home page - some really cool stuff on here. Later.
Old 11-23-2016, 05:43:26 PM
gdstew gdstew is offline
Probably keyed shaft, just pulls straight off.
Old 11-24-2016, 12:56:57 AM
CharlieB CharlieB is offline
Wisconsin made many styles of crankshafts for OEM customers. I've seen shafts with standard keyways, woodruff keyways, stepped shafts, tapered shafts, threaded shafts, internally threaded shafts, and various combinations of the above. Sometimes it's impossible to identify what you have after the accessory is installed on the shaft. The only way to know for sure is to have a Wisconsin guy look up the spec number.
Wisconsin AENLD Gbell Antique Engine Photos 1 06-25-2014 10:26:49 AM
wisconsin aenld dirtycurt Wisconsin Engines 11 04-25-2012 08:33:12 AM
Wisconsin AENLD AndyG Wisconsin Engines 3 11-12-2009 09:51:22 PM
Wisconsin AENLD Bill Sherlock Wisconsin Engines 4 05-09-2009 02:05:52 AM
Wisconsin AENLD Ken Antique Engine Archives 2 11-17-1999 12:10:03 AM
